+3
pigface
7 posters
Woody M-125s
deepee99- Posts : 2244
- Post n°1
Woody M-125s
At the risk of setting a house fire, has anybody messed about with building a woody chassis for the m-125s?
pigface- Posts : 85
Re: Woody M-125s
I haven't yet but I am thinking about it this summer . Something that will match the SP14 I just built .
I'm planning on bi-amping my new ( to me ) speakers and if my ST120 will not run the highs I'm going to build the M125's.
Or maybe just make a cover like I did on the ST120.
Re: Woody M-125s
The M-125s will not disappoint.
sKiZo- Posts : 1530
Re: Woody M-125s
pigface wrote:I haven't yet but I am thinking about it this summer . Something that will match the SP14 I just built .
I do remember you having some cracking issues on the top of your pre ...
https://dynacotubeaudio.forumotion.com/t1983-my-new-sp14-build
Oh. And not to miss an opportunity to once again say ... beautiful work!
Not to forget, unlike a straight bottle like those used on the pre, the KT tube shape also radiates some heat down, so I'd think it'd be even more of an issue with an amp, even if you keep the sockets proud of the top.
Re: Woody M-125s
sKiZo wrote:pigface wrote:I haven't yet but I am thinking about it this summer . Something that will match the SP14 I just built .
Skiz,
Forgive me for being too lazy to find it here (wish they had a search engine) you had some tube-lifters? Could you zap a link?
sKiZo- Posts : 1530
- Post n°6
Re: Woody M-125s
Seems my source has dried up with the old bakelite risers.
Do a search for "tube socket savers" ... lotsa hits on that auction site ...
I'd send you some, but mine are all in use ...
Guest- Guest
- Post n°7
Re: Woody M-125s
sKiZo wrote:Seems my source has dried up with the old bakelite risers.
better watch out, could end up like the leaning tower of Pisa!
corndog71- Posts : 840
- Post n°8
Re: Woody M-125s
sKiZo wrote:
Maybe you should just mount it to your ceiling and use it as a light source.
sKiZo- Posts : 1530
- Post n°9
Re: Woody M-125s
Great idea! Been looking for a nice reading lamp!!
Instead of the GZ37, I could get a LOT more light out of a Chinese 5AR4 ... put that nuclear glow to work!
We'll have a race to see who burns down first, me with the paper shade, or deepee with a wooden chassis ...
- Post n°10
Re: Woody M-125s
My money's on the lamp shade. Iron bark doesn't burn, it just sinks.
pigface- Posts : 85
- Post n°11
Re: Woody M-125s
Thanks . Ya , With the big KT120's and big rectifier in them there would be alot more heat . I wouldn't even consider a wood top for the M125's !
I was thinking of doing like the SP14 and making a brass top and I was thinking of hiding the circuit board and quad cap inside the case like SkiZo's and moveing the small tube sockets off the board to the top.
Or to just use the top of the stainless M125 housing and screwing it to a wooden case .
Or just doing like my ST120 . Build the amps normally and make a wooden case and the amp just slides down in the wood case .
Deepee , I have 5 octal socket savers I'll give you a deal on if you want them . I don't need them now .
- Post n°12
Re: Woody M-125s
PF
Sweet!
Yeah, I wasn't thinking of a wood tube cage. Our fire department is pretty drunk and slow most good days. Their motto is: We saved the lot. There;s a wood-butchering shop over in Spokane about 90 miles away, maybe I'll take an M-125 in there and see what they can do with it.
PM me on those socket-savers, we'll work work something out.
Dave
Sweet!
Dave
Guest- Guest
- Post n°13
Re: Woody M-125s
pigface wrote:Thanks . Ya , With the big KT120's and big rectifier in them there would be alot more heat . I wouldn't even consider a wood top for the M125's !
nice job on the wooden box!
jjones3318- Posts : 57
- Post n°14
Re: Woody M-125s
Here's a pair I did.
sKiZo- Posts : 1530
- Post n°15
Re: Woody M-125s
Mirroring the layout was a real nice touch.
pigface wrote:I was thinking of hiding the circuit board and quad cap inside the case like SkiZo's and moveing the small tube sockets off the board to the top.
If you decide to hide the board, I used threaded spacers from the local hardware.
You can always adjust the length of those to suit. Also, all the large caps are mounted on the "wrong" side of the board. The VTA board has double sided pads which makes that easy.
5/35- Posts : 15
- Post n°16
Yes
I am guessing this is what you mean by woody. No scorching or smoke yet. I do know were the fire extinguisher is at all times however.
https://dynacotubeaudio.forumotion.com/t2153-another-convert-m-125-build
audiobill- Posts : 425
- Post n°17
Re: Woody M-125s
sKiZo wrote:Great idea! Been looking for a nice reading lamp!!
Looks like an e-rectifier!
