I would be very much interested in what you all would prefer, thank you.
Ok people, this is not a trick question ......... how about some votes.......
You neglected to mention the new unobtanium power cables for sale now; $25,000/ft and IEC connectors are extra. guaranteed to improve frequency response curves past the 200,000 Hz level (at 1 watt, of course).pmarcin wrote:I think you may be going over the top with this add-on. Why not outlet covers, Bybee quantum filters, etc? (Listed as snake oil on the diytube site.)
MontanaWay wrote:no, this is a general question. I will still built an EQ based on the old Blonder-Tongue, but probably in stereo.
Do I really need it?, no, the sound coming out of my system, to my ears, is pretty darn perfect.
So why bother?....cause I can and its a good learning curve AND its fun. I like tinkering
The reason for this question is space, that is space in the chassis. I can squeeze it into the chassis I am thinking of using, it would be easier to build a mono in each chassis, but of course the cost would be higher.
Yes, I know how technical sound analysis etc can get, but lets face it, this is a hobby, for me anyway, and like I said above, its fun tinkering.
Thank you for all the input and ideas, much appreciated!
deepee99 wrote:MontanaWay wrote:no, this is a general question. I will still built an EQ based on the old Blonder-Tongue, but probably in stereo.
Ahhhhhh, space, the final frontier. I spent a delightful afternoon last Fall on the phone with a guy in California who builds million-dollar stereo listening rooms (we were arguing over whether tubes trumped s/s or not, voltage regulation, and such).
He said more can be accomplished with speaker and/or listening chair placement than any electronic tweak in the >$100,000 investment in electronics. And he was right; I was always wondering why the bass was better on my right channel than my left. Well, my RH speak is up against a corner wall; the left is up against am open wall. I walked that RH speak out of the corner a little bit, less than a foot, and Voila! no more imbalance. The room is everything.
I'd hate to see you put an EQ into the signal path, that's all. Any EQ induces distortion -- which is of course the point -- but it also invites other issues like RF and AC noise into the equation.
I'd crack open a decent bottle and bribe a friend over to the crib to move your speaks around while you sit in your favorite place. You would be amazed at what a foot or two, and some toeing in and out can do. And except for the price of the Scotch, it's a cheap fix.
Just IMHO. Sometimes, when it's as good as it gets,that's as good as it gets. So go blow a kilobuck on an Ortofon cartridge and spend some time on the turntable alignment. They DO make a difference.
My uber-rich California guy also said voltage fluctuations should not be an obsession; our tubes can handle a 10 percent swing and that's well within the 6.3-7 volt tolerance of our filaments. Bias your tubes at night when line demand is low and volts are high coming out of the wall, and you'll never cook 'em.
tubes4hifi wrote:I have been considering building and offering for sale a hybrid tube EQ and/or crossover. To do either right, with all tubes, would require DOZENS of tubes,
but if combining tubes and audiophile quality discrete op-amps such as those used in $500-2000 audiophile gear, it's not such a huge task,
can be done with maybe 4-8 tubes total. So I'll add to the question, is anyone interested in either EQ or crossover using tubes?
Paul, this would be similar to the XM9 but using a mix of tubes and op-amps.
MontanaWay wrote:tubes4hifi wrote:I have been considering building and offering for sale a hybrid tube EQ and/or crossover. To do either right, with all tubes, would require DOZENS of tubes,
yup, I am...you betcha, put me down....gimme more gagdets....gadgets gadgets gadgets!!......
Tube Nube wrote:One place where EQ can add big value with minimal audible distortion is in the subwoofer frequency range. Parametric eq built into many subs is useful for taming room modes. The ringing of standing waves at those mode frequencies has a detrimental effect on our ability to hear other frequencies.
Yet the downsides of adding equalization, cross-overs, etc are minimized by the insensitivity of our hearing in those frequency ranges--we wont hear cross over distortion etc in the low registers the way we do in the vocal range where our hearing is very sensitive.
So in answer to your question, mono. I have two mono parametrics, one built into each of my 2 Rythmik subwoofers. One is taming a room mode at 70Hz, the other at 46Hz.
sKiZo wrote:Don't forget your toes!
