    New VTA board (Prebuilt) Voltage Problems
    aguaazul
    aguaazul
    New VTA board (Prebuilt) Voltage Problems Empty New VTA board (Prebuilt) Voltage Problems
    Post by aguaazul Sun Jun 29, 2014 3:06 pm
    Hi, I've double checked my wiring / soldering. I can't get any Filament or B+ Voltage.
    Joe Curcio replaced the octal sockets and ran a strait, tight jumper for the Filament connections.
    Here are some pictures, any help is appreciated.
    Thanks, Blue
    New VTA board (Prebuilt) Voltage Problems 1-DSCN2389_zpsc73daa0e
    New VTA board (Prebuilt) Voltage Problems 2-DSCN2392_zps8471a60b
    New VTA board (Prebuilt) Voltage Problems 4-DSCN2396_zpsda1b7393
    New VTA board (Prebuilt) Voltage Problems 3-DSCN2395_zpsea72f2fd
    New VTA board (Prebuilt) Voltage Problems 5-DSCN2397_zpse0d52d98
    New VTA board (Prebuilt) Voltage Problems Empty Re: New VTA board (Prebuilt) Voltage Problems
    Post by Guest Sun Jun 29, 2014 5:41 pm
    we are assuming that you are getting filament voltage out of your transformer?
    aguaazul
    aguaazul
    Post by aguaazul Sun Jun 29, 2014 6:49 pm
    Yes, 6.7v on both sides measured at the bottom of the driver board.  I just brought it into a darker room. The tubes are lighting up. It's hard to see under the Silver Domes of the EH Tubes.
    Last edited by aguaazul on Sun Jun 29, 2014 6:59 pm; edited 2 times in total (Reason for editing : Saw the tubes light up!)
    Post by Guest Sun Jun 29, 2014 7:56 pm
    what about the B+?....still 'missing'?
    aguaazul
    aguaazul
    Post by aguaazul Sun Jun 29, 2014 8:08 pm
    Nope, we're all good. Breaking it in now. Thanks.
    Post by Guest Sun Jun 29, 2014 8:19 pm
    aguaazul wrote:Nope, we're all good. Breaking it in now.  Thanks.
    good to hear, enjoy your 'new' Dynaco!
    Post by Roy Mottram Tue Jul 01, 2014 2:54 pm
    so what was the problem? bad connection somewhere?
    aguaazul
    aguaazul
    Post by aguaazul Wed Jul 02, 2014 12:58 pm
    Everything was fine, it was me being extra careful. 1st, the light in the room where I was testing to see if the tubes lit up was too bright. I was measuring filament voltage to ground, when I measured the filament voltage from the transformer on both leads, I had the power I needed, everywhere that it should be. After closing the drapes, the gentle glow in the driver tubes could be seen. As I moved through the next steps, everything came out perfect.
    So the problem, "Me!" being told to check the transformer voltage was the 'AH HA' moment.
    Going to dial in the PAS now. It's in the mail!
      Current date/time is Fri Apr 26, 2024 9:14 pm
