    Can 6GH8 plug n Play on VTA ST-120 ?
    EddieGnz1
     Can  6GH8  plug n Play on VTA ST-120 ? Empty Can 6GH8 plug n Play on VTA ST-120 ?
    Post by EddieGnz1 on Tue May 27, 2014 6:22 pm
    I found a way to buy a 6GH8 that someone was using on their ST-70. Will it work as the center tube on the ST-120 driver board ?
    thanks,
    Eddie
     Can  6GH8  plug n Play on VTA ST-120 ? Empty Re: Can 6GH8 plug n Play on VTA ST-120 ?
    Post by GP49 on Tue May 27, 2014 7:33 pm
    No, you can not do that.
    Not only do the pinouts differ; the tubes are of two different types.
    The center tube of the ST-120 is a twin triode, nominally a 12AU7.  The 6GH8A is a pentode-triode.
    "Someone" was probably using the 6GH8 to replace the 7199 pentode-triode in a STOCK Dynaco Stereo 70 (a wiring change is required, the 7199 has yet another different pinout) but that amp has a totally different driver/inverter circuit from that in the ST-120.
    6GH8:
     Can  6GH8  plug n Play on VTA ST-120 ? 9ae
    12AU7:
      Current date/time is Thu Feb 27, 2020 10:12 pm
