    Installing VTA Board - Strange Pin Connections to Sockets on Existing setup
    aguaazul
    aguaazul
    Installing VTA Board - Strange Pin Connections to Sockets on Existing setup Empty Installing VTA Board - Strange Pin Connections to Sockets on Existing setup
    Post by aguaazul Mon Jun 09, 2014 7:51 pm
    My ST-70 was brought up to spec a few years ago. The tech installed new milSpec sockets.
    The connections to Pin(s) 1 & 2 - 22 & 23 are just a simple 1k resistor to pin #5 on the sockets. Pin 6 has nothing connected to it.
    Should I put the resistor back @ 5 - 6 and connect 6 to the new Driver Board? Did he use a socket that needs this configuration?
    Blue
    aguaazul
    aguaazul
    Installing VTA Board - Strange Pin Connections to Sockets on Existing setup Empty Re: Installing VTA Board - Strange Pin Connections to Sockets on Existing setup
    Post by aguaazul Mon Jun 09, 2014 7:58 pm
    Here is a picture:
    Resistor Connection
    Post by Bob Latino Mon Jun 09, 2014 9:16 pm
    aguaazul wrote:My ST-70 was brought up to spec a few years ago. The tech installed new milSpec sockets.
    Blue
    You can do either ..(1) Run the 1K resistor directly to pin #5 or (2) run a wire to pin #6 and run the 1K resistor across pins 5 and 6. Pin#6 is NOT USED in octal output tubes so pin 6 is just a tie off point for the 1K resistor. It is interesting to note that all the FACTORY WIRED Dynaco ST-70's ran the resistor directly from the driver board to pin 5 - BUT - If you wired up the ST-70 from a KIT, the kit assembly manual told you to run the wire from the driver board to pin 6 and then the 1K resistor across pins 5 and 6. See photo below .. Note that on the factory wired amp there is no connection on pin #6 - it is empty on all four output tube sockets.
    Installing VTA Board - Strange Pin Connections to Sockets on Existing setup ST-70internalwiringcomparison
    aguaazul
    aguaazul
    Post by aguaazul Tue Jun 10, 2014 12:45 am
    Great News!
    Montana Way, yep, I've got a prewired VTA driver Board that I'm installing. (nice fish)
    Bob, Thank you for explaining it to me. I'll run the 1k resistor across 5-6. It will give me easier wiring in the long and short of it all. I saw in the schematics that 6 had no connections. Now I'm sure.
    I'm looking forward to hearing this new VTA driver board!
    Blue
    Post by Roy Mottram Tue Jun 10, 2014 11:41 am
    nice photo comparison Bob, I think we get this question at least once a month
    aguaazul
    aguaazul
    Post by aguaazul Tue Jun 10, 2014 12:24 pm
    I searched the forum with at least 3 different queries before I posted. What could I have searched to find this answer?
    Post by stewdan Tue Jun 10, 2014 12:35 pm
    Hi aquaazul -- actually, I think you would have had to know exactly what to look for ... sometimes I can find things via queries and sometimes it just a question of knowing what to look for, since I saw it once or twice before.
    The info that you needed is in a STICKEY with the title: " Differences between factory wired and kit built ST-70 - photos .. "
    Stew
    aguaazul
    aguaazul
    Post by aguaazul Tue Jun 10, 2014 12:46 pm
    That makes sense Stew. I try hard to find the answers myself without bothering others, so I’m grateful that I was able to get the help I needed so quickly. I’ll take your advice, read through the STICKY posts.
    I read the post on Safety, very valuable info for sure.
    I got the old driver board out, found the brown goo issue on the choke, ordered the Triode model (found that one in a search). Will take the time now to do a little polishing while I’m waiting for shipping ;-)
      Current date/time is Fri Apr 19, 2024 2:03 pm
