    uTracer 'tube tester'
    Pillo69
    Pillo69
    uTracer 'tube tester' - Page 2 Empty Re: uTracer 'tube tester'
    Post by Pillo69 on Sun Jul 31, 2016 8:25 am
    The power supply uses the uTracer is a power transformer 19v laptop computer.
    I'll leave some bananas to connect an external power supply, it will be necessary for valves and low voltage high amperage.
    Pillo69
    Pillo69
    Post by Pillo69 on Mon Aug 01, 2016 4:36 pm
    Peterh, how to solve the amplification (mu) of a high-gain pentode ??.
    For example, EF184 has a mu of 5250 and in the "Name" box in the "Quick Test" only allows a maximum of 1000.
    uTracer 'tube tester' - Page 2 Mu_alta_ganancia
    Post by peterh on Mon Aug 01, 2016 5:06 pm
    Pillo69 wrote:Peterh, how to solve the amplification (mu) of a high-gain pentode ??.
    Is it the TDSL app that limits mu ?
    Then file a bug.
    Pillo69
    Pillo69
    Post by Pillo69 on Mon Aug 01, 2016 6:34 pm
    Limiting "mu" is the version uTracer v3p11 the program.
    I enter 5250 value, perform pulse test, text box appears, and value is changed to 1000.
    1000 is the maximum value.
    uTracer 'tube tester' - Page 2 Mu_alta_ganancia_01
    Post by peterh on Mon Aug 01, 2016 6:56 pm
    Pillo69 wrote:Limiting "mu" is the version uTracer v3p11 the program.
    Ok, it's in the 3.11 GUI .
    This is values that ( according to the documentation http://www.dos4ever.com/uTracer3/uTracer3_pag5.html#quicktest2):
    "When the nominal values for the currents and derivatives are known they can be entered in the fields labeled “Nom.” These nominal values are used at the end of the test to calculate the relative deviation of the measured value from the nominal value. The values entered do not affect the measurement. When the nominal values are not known these values can be left at 0 so that they are not taken into account. "
    I'm not sure here, but leave them as zero and  see what values are measured
    when actually measuring a tube. You might have a scaling issue.
    mu for a pentode is a "fuzze value" anyway, just like it's Ra.
    Pillo69
    Pillo69
    Post by Pillo69 on Mon Aug 01, 2016 7:03 pm
    Anyway I checked other valves in Datahet and "mu" value is the amplification factor.
    For example 12AX7 the "mu" value is 100.
    Therefore in EF184 the "mu" value should be 60 (according Datashet), not 5250 as indicated TDSL.
    It must be an error in the TDSL program.
    Post by peterh on Tue Aug 02, 2016 3:22 am
    Pillo69 wrote:Anyway I checked other valves in Datahet and "mu" value is the amplification factor.
    It was a "scaling error then".
    mu is a value that depends on working conditions as well as the tube under test, thus mentioning mu without mentioning other conditions is of little value.
    The above uTracer menue is used to establish a baseline value for a tube, and when choosing the conditions to measure this i would suggest looking in the tubemakers own documentation, both to get a suggestion of working point and also to get typical values of the tubes performance.
    https://frank.pocnet.net/sheets/010/e/EF184.pdf is one such source, scroll down to "Typical characteristics" and use the values as initial conditions for the quick test.
    The results of the quick test ( Ra, Gm and mu ) should then be compared to the measured values ( 380kohm, 15mA/V and 60 )
    Note that tubes are mechanical animals with large tolerances ( +-20% is not uncommon ), this was the designers "of the day" aware of and made the designs
    in a way that the tolerances were unimportant and did not affect the amps performance. The general exception is matching tubes used in push-pull applications.
    Post by Peter W. on Fri Aug 12, 2016 9:20 am
    peterh wrote:
    Tube Nube wrote:There's something mildly amusing about a tube tester that uses silicon chips.
    >>A tube "tester" is either to simple to be of any value, or to simple to be of any general value.<< Snippage
    Well... and a simple answer may not be so.
    A well made GM tester does many things well, but, yes, it does not trace curves, agreed. Nor, for a fact, do most audio applications require curves to be traced. A typical audio tube is far too crude a device for to be of much benefit. The best analogy that applies is a choke on a shotgun. One will never get the spread down to to the diameter of the barrel, one might get it to scatter a bit less over a short range, but a shotgun remains a shotgun.
    I keep a Hickok 539B, a lab-grade tester that I obtained (legitimately) from the GE Re-entry Systems Division in Philadelphia some time after they closed their doors, fully calibrated, and with a set of calibration tubes as well. Using external meters, I can test for plate current, filament current and voltage, set specific bias voltages and thereby actually "match" tubes. No, again, I cannot trace a performance curve. But, the 539B is a fine tester, and within the universe of commercially manufactured units from back in the day, is surpassed only by (and perhaps) the AVO testers from England, and its newer brother, the 539C. No chips, of course. BUT, I have solid-state rectifiers in place, explicitly necessary for the 83 mercury rectifier not rated to be used horizontally, and also notoriously unreliable. The 5Y3 is a bit more reliable, but replacing it with a SS device is simple and certain.
    But, within the broad range of tubes free of basic failures (shorts, gas, saturated cathodes and such, all of which would be manifest on a good tester), the best test for any given tube is the equipment it is in.
    I am by no means a Luddite, and I see great appeal  in a curve tester such that if I were to be designing new tube equipment such would be in my equipment inventory. But, I do not. I keep several dozen tube devices, mostly vintage radios, but also two complete tube-based audio systems including a Scott LK150. Nothing exotic however. None of it requires screening tubes with the precision that a curve-tracer would offer.
    Pillo69
    Pillo69
    Post by Pillo69 on Thu Aug 18, 2016 7:34 pm
    Today I tried a 6CA7-EH ST-70 amplifier, tube is in use since 2011. These are the results.
    uTracer 'tube tester' - Page 2 Medicion
    uTracer 'tube tester' - Page 2 Gr_fico_2
    uTracer 'tube tester' - Page 2 Grafico_3
    Post by peterh on Fri Aug 19, 2016 2:36 am
    Nice !
    BNR_1
    Post by BNR_1 on Fri Aug 19, 2016 10:26 pm
    I am a newbie. So I take that test results > 90% are good. This is for one tube only. Correct? Can you share your thoughts as to what is the take away from these results.
    On a separate note, I tried the EH 6CA7 (big bottle) and was impressed by the sonic quality. Unfortunately, I could not bias my amp (ST-70) higher. It was on the cold side, but I am most certain it had nothing to do with the tube, but more of my setup. I can only imagine if this tube bias right how much better it would sound.
    Thanks for sharing.
    Pillo69
    Pillo69
    Post by Pillo69 on Sat Aug 20, 2016 7:35 pm
    It is a test on a single tube of a quartet purchased in 2011.
    ST 70 amplifier is used daily. The hours of operation are greater than 2000 hours.
      Current date/time is Sun Aug 18, 2019 3:55 am
