    sp14 preamp is 220v or 110v
    vuthecuongjapan
    sp14 preamp is 220v or 110v Empty sp14 preamp is 220v or 110v
    Post by vuthecuongjapan Sat Jun 21, 2014 8:55 pm
    Hi all,
    my ordered sp14 preamp just has comed and I unboxed it.
    But still not plug it to the electric power yet.
    I dont know it's elcectric power is 220v or 110v. Could anyone tell me.
    thank you
    sp14 preamp is 220v or 110v Empty Re: sp14 preamp is 220v or 110v
    Post by Guest Sat Jun 21, 2014 10:05 pm
    vuthecuongjapan wrote:Hi all,
    thank you
    unless you specified 220V when you ordered the kit, standard is 120VAC 60Hz
    vuthecuongjapan
    Post by vuthecuongjapan Sat Jun 21, 2014 10:18 pm
    I understand. I should buy a 220-> 110 transformer now.
    thank you
    jjones3318
    jjones3318
    Post by jjones3318 Sat Jun 21, 2014 10:38 pm
    The power transformer may have dual primaries. On the Antek transformers for example, you can wire for 115 with the primaries in parallel, or 230 with the primaries in series.
    vuthecuongjapan
    Post by vuthecuongjapan Sat Jun 21, 2014 11:03 pm
    thank you for your advice. I cannot wait
    Post by Guest Sun Jun 22, 2014 12:50 am
    that is a correct point, I did not think of that.
    Not sure which model the SP14 uses. I assume it is the AS-05T240, http://www.antekinc.com/as-05t240-50va-240v-transformer/, it will take you to the manufacturers web site showing you the wiring diagram of that toroid transformer.
    You should be able to see details on the label of your transformer.
    vuthecuongjapan
    Post by vuthecuongjapan Sun Jun 22, 2014 3:54 am
    I started listening from SP14 with dynaco st 70 stock mod output to my old klipsch la scala,
    it blow my mind.
    thanks.
      Current date/time is Thu Mar 28, 2024 3:49 pm
