    ST-70 Series 2 refurbishment
    offanonone
    ST-70 Series 2 refurbishment Empty ST-70 Series 2 refurbishment
    Post by offanonone on Tue Jul 29, 2014 8:00 am
    Hello to everyone from a new member in the UK.
    I have just got a new to me Dynaco ST-70 Series 2, and are about to start work on it.
    I have already got replacement Elec Caps, so that will be the first job when time allows.
    The chassis is a little battered & bruised in places so I will probably remove the transformers to allow a little panel beating to be carried out safely.
    So now the request for help Very Happy
    The original bias resistors fitted are 15ohm, not 15.6ohm as stated on the circuit.
    If I replace these with some 10ohm 2 watt (that I have in my bits box), would the bias circuit still work with the hi-lo leds and give a lower bias current ??
    I am also thinking of doing the Triode mod, and putting the switches on the front in place of the input rca's.
    And also removing the unused 16ohm speaker connectors, and putting new insulated input sockets on the rear. (I don't like uninsulated sockets grounded to the chassis on the front)
    What else should I replace or check?
    John
    Last edited by offanonone on Tue Jul 29, 2014 9:37 am; edited 1 time in total (Reason for editing : Corrected some of my bad spelling!!)
    ST-70 Series 2 refurbishment Empty Re: ST-70 Series 2 refurbishment
    Post by Guest on Tue Jul 29, 2014 8:26 am
    my best advise to you is to consider the VTA driver board upgrade, it will make a huge difference to the sound of the amp!
    It is available from Tubes4Hifi.com.
    Have you ran the amp at all?
    MarcVBelgium
    MarcVBelgium
    ST-70 Series 2 refurbishment Empty ST 70 series 2
    Post by MarcVBelgium on Tue Jul 29, 2014 9:26 am
    MontanaWay wrote:my best advise to you is to consider the VTA driver board upgrade, it will make a huge difference to the sound of the amp!
    Forgive my interfering.... but as far as I know there is no VTA driver board for the series 2 ST70 (which was made by Panor in the nineties). On that amp, all the electronics is on one big PCboard, even the tubes...(I have one of those....)
    offanonone
    Post by offanonone on Tue Jul 29, 2014 9:32 am
    Thanks for your reply Marc, and yes, its all on one board, so none of the aftermarket driver boards are a drop in replacement.
    As these are quite scarce in the UK, I want to keep it close to the original, with any mods easily reversable.
    John
    Post by Guest on Tue Jul 29, 2014 10:10 am
    ah ok, thanks for the correction, was not aware of that :-)
    Post by peterh on Tue Jul 29, 2014 10:32 am
    offanonone wrote:Hello to everyone from a new member in the UK.
    John
    The bias adjustment circuit depends on the "correct value" of cathode resistors. Why don't
    you let them be in place ?
    Post by corndog71 on Tue Jul 29, 2014 11:17 am
    John
    If I remember correctly the 15.6 Ohm resistors were an unusual value. If these were foreign made they probably went with whatever they had that was closest.
    http://www.dynakitparts.com/dynakit-products/bias-kit-parts/ST-70-BIAS-RESISTOR
    Personally, I prefer to use 10 Ohm resistors as they give you a more accurate reading but it won't match the label on the chassis.
    offanonone
    Post by offanonone on Tue Jul 29, 2014 11:53 am
    The ST-70 Series 2, uses 2 led's that are adjusted with a multiturn pot until they are equal brightness. I assume with the original 15.6ohm resistors, that equal brightness would equate to 100mv or 50mv per tube.
    My question is would changing them to 10ohm still allow the bias adjustment to work in the same way, giving total 80mv and when the led's are equal, a balanced 40mv each tube ??
    John
    anbitet66
    anbitet66
    Post by anbitet66 on Tue Jul 29, 2014 12:22 pm
    John,
    If you look at your schematic, there are 2 resistors to set the brightness of an LED that you will use to compare while you adjust the bias with the other LED.  It is these resistors (R10= 6.65K and R4= 1k) which sets the LED brightness at 1.56 volts.  If you change R10 or R4, you can adjust the circuit to whatever conditions you'd like.  If you want to go to say a 10 ohm resistor for bias, and you are looking for 40mA per tube, then you will need an 0.8V drop on the 10 ohm resistor.
    The next problem will be getting the bias circuit to match.  By my calculations, if you change R4 to a 470 ohm resistor, you will set the voltage divider network to output a voltage of almost exactly 0.8 volts, matching the new bias you are looking for.
    Lets wait to see if anyone else agrees with me  scratch  .  I need to wait for the smoke to clear with all that thinking I had to do anyway...
    Tony
    Post by tubes4hifi on Sat Aug 02, 2014 7:21 pm
    Tony has it almost correct, I calculate a slightly different value. If you replace the 15 ohm R8 and R9 cathode resistors with 10 ohms,
    you will need to change R4 which sets up the window for the LEDs. The 1K R4 sends 1.56v to compare to cathode bias of 50ma per tube.
    Using 10 ohm resistors at R8 & R9 you would want R4 to be 510 ohm to correct the change, and 0.85v would indicate 40ma per tube.
    If you need the manual or schematic it is on my website here: www.tubes4hifi.com/downloads.htm
    The ST70 series 2 is about half way down the page, third row, 2nd from right.
    Dogstar
    Post by Dogstar on Tue Aug 05, 2014 8:59 pm
    Can you post a photo of that amp?
      Current date/time is Sun May 19, 2019 7:42 am
