+7
tubenutr
mazeeff
anbitet66
DynakitParts
11 posters
    Dynakit ST-70 Covers
    DynakitParts
    DynakitParts
    Dynakit ST-70 Covers Empty Dynakit ST-70 Covers
    Post by DynakitParts Fri Dec 04, 2015 3:46 pm
    Hi All...
              Just a note to say we have stock again on our ST-70 top vented covers. We have been out of stock
    on these covers for more than (10) months due to various material supply issues. For those who may not
    know...Our ST-70 covers will fit Bob Latinos VTA ST-70 & ST-120 perfectly. Aside from our standard "Brown" covers we also have a small limited supply of these covers in a "Black" textured finish with NOS Dynaco black & white labeling. These are not offered on our website...Email me if you have any interest in these special "Black" covers. www.dynakit.com
    Happy Holidays guys...
    Kevin @ Dynakit
    Dynakit ST-70 Covers Empty Re: Dynakit ST-70 Covers
    Post by peterh Fri Dec 04, 2015 4:30 pm
    DynakitParts wrote:Hi All...
    Kevin @ Dynakit
    Are they made of non-magnetic ( stainless steel ) ?
    The originals will hum violently when mounted on a vta with the large transformer.
    DynakitParts
    DynakitParts
    Dynakit ST-70 Covers Empty ST-70 Covers
    Post by DynakitParts Fri Dec 04, 2015 10:08 pm
    Peteh,
    Making these covers using non-magnetic stainless steel would not in my opinion eliminate any hum originating from the power transformer.
    I have sold quite a number of these covers to customers for their VTA new or upgraded ST-70 amplifiers. I have never had one complaint and/or issue
    as you have suggested. Maybe others would like to comment on this?
    Merry Christmas
    Kevin
    anbitet66
    anbitet66
    Post by anbitet66 Fri Dec 04, 2015 10:29 pm
    Kevin,
    What Peterh is saying is the cover being so close to the power transformer and made of steel may itself vibrate because of the alternating magnetic field in the power transformer.
    It reminds me of an amp I sadly no longer own, that did exactly that, except it had a removable rear plate held in by just a couple of the smallest of sheet metal screws and years of tinkering by the original owner didn't help.  Removing the cover went a long way to quiet that hum and the "boing" of turning the amp on at just the right moment of the 60hz power cycle!
    Just a thought.  Tony
    Post by Kentley Fri Dec 04, 2015 10:33 pm
    I occasionally use the original Dynaco ST-xx cover on my VTA ST-120. It's mostly for use when the amp is off, but sometimes when the felines are rambunctious......Anyway I have never heard even a hint of vibration or noise.
    Post by peterh Sat Dec 05, 2015 3:01 am
    As Tony, said : yes it's the magnetic field that leaks from the transformer that set's the cover
    in vibration. And maybe the cover vibrates more on 50 Hz then 60 ...
    A stainless cover could also be kept without the need for paint, thus nullifying part of the
    cost.
    mazeeff
    Post by mazeeff Sat Dec 05, 2015 5:06 am
    anbitet66 wrote:Kevin,
    Wow! I have a VTA-70 with the cage, and have been fighting the "boing" (or Thunk) issue, since I got the amp. Removing the cover fixed the problem! The "boing" was quite loud on the VTA-70, and never occurs on my ST-70, with cage. The "boing" would occur about half the time at power on, and I always assumed that it was the transformer windings lining up. Thanks for fixing my very annoying problem!
    Mike
    Post by Bob Latino Sat Dec 05, 2015 9:20 am
    I have here my VTA ST-120 with a tube cage on it. I never experienced any "thunk" or "boing" noise issue at turn on. You may want to check the amount of tension that you have on those 4 isolation washers that are between the chassis and the transformer mounting screws. If they are either too tight or too loose, you may get a slight amount of mechanical noise from the power transformer. The noise you hear may also be related to the fact that some tube cage users with VTA amps do not use the hold down screws for the tube cage because you have to remove the tube cage to rebias the amp? Possibly the screws that hold down the tube cage are maybe even too tight ?
    Maybe others who do use a tube cage could chime in here concerning any turn on noise with their amps when using a tube cage.
    Post by peterh Sat Dec 05, 2015 9:55 am
    I gave my cover away to a friend ( who build a nice richardson clone) as i could not use it.
    The cover was bought from ebay/canada but i have every reason to belive that it was genuine.
    The vibrations was violent, and it was right above the mains transformer, and it was by
    magnetic attraction/replulsion .
    mazeeff
    Post by mazeeff Sat Dec 05, 2015 11:21 am
    I checked the power transformer mounting screws, and they are just right. My chassis/cage screws are always installed, and snug. Without the four chassis/cage screws, there is nothing to keep the chassis halves together! I ran a number of tests with the cage off/on, and the Thump is there with the cage on. I would point out, that my VTA-70 is SS rectification with no time delay. I am hitting the transformer pretty hard at power on. Also, the amp sits three feet from my listening position, so any amp sound is magnified.
    Mike
    Post by Bob Latino Sat Dec 05, 2015 11:25 am
    Mike,
    You should try the amp with a TUBE rectifier and see if you still get the thump on start up. Maybe the solid state rectifier is the cause of the turn on noise.
    mazeeff
    Post by mazeeff Sat Dec 05, 2015 12:03 pm
    Bob Latino wrote:Mike,
    With my 5AR4 tube rectifier installed, the thump is gone, with the cage on. With my Weber WS1 (No sag resistor), the thump is present, with the cage on! The cage is either mechanically amplifying the transformer thump, or is magnetically coupling, as previously pointed out. Either, way, I can live with the thump. I like the tight bass that I get with the WS1.
    Mike
    DynakitParts
    DynakitParts
    Dynakit ST-70 Covers Empty ST-70 covers
    Post by DynakitParts Sat Dec 05, 2015 1:03 pm
    To all..
             My original post was intended for the Announcement section of the forum and not the general discussion section.
    The comment by Peterh that the use of the cover will result in violent vibration or hum may in fact be true with regard to
    his specific amplifier. However, to suggest that this is a common problem with all ST-70 amplifiers or more specific to those
    units that incorporate upgraded power transformers typical of what is provided in both my Dynakit ST-70 and the VTA
    versions is completely unfounded. The potential consequences of your comments may impact my sales of these covers to those
    forum members who read these posts. My Dynakit business is more of a passion than a profit enterprise...
    Most vendors like me are small business owners and often just a one man operation. Our opinions are often accepted as
    facts and sometimes we get these two confused.
    Peter...I respectfully disagree with your comments regarding the use of the cover.
    Happy Holidays
    Kevin @ Dynakit
    Post by Maintarget Sat Dec 05, 2015 4:52 pm
    I'm the happy owner of an VTA ST-120 and use a ST-70 cover that I bought from Dynakit in December 2013
    I have experienced the thump sound on start up that Peter has described, I do not use the screws supplied with amp or cover and have used both tube & SS (Copper cap) rectification it doesn't happen consistently every time but in my case with my amp it is happening once i had my suspicions about what was going on I verified it by placing my hand on the back of the cover on start up and could actually feel it move slightly.
    Now I want to be crystal clear
    "I Love the look of the cover and have curious grandchildren I want to keep safe, The cover Kevin supplies is a quality piece that I would recommend to others with no hesitation"
    Post by Guest Sat Dec 05, 2015 6:00 pm
    tubenutr
    tubenutr
    Dynakit ST-70 Covers Empty Dynakit covers
    Post by tubenutr Sat Dec 05, 2015 6:45 pm
    Greetings,
    I do not use the cover. Personal preference. I like my tube amp naked.
    As far as using the cover, would installing copper foil on the cover near the
    PT eliminate the problems? Just a thought.
    Post by Maintarget Sat Dec 05, 2015 8:11 pm
    PeterCapo agreed it doesn't bother me in the least I have the TDB in my ST-120 Amp and a Schiit Gungnir DAC they both have relays that click and have no effect on the sweet tube sounds from my system.
    j4570
    Post by j4570 Thu Dec 10, 2015 3:13 pm
    I have a rebuilt original ST-70 that was upgraded to VTA specs. I reused the original output transformers but used the upgraded VTA-70 power transformer. I always run the cage with the screws snugged up holding it on (except when bias adjusting). I have had no mechanical hum issues.
    Jason
    Post by peterh Thu Dec 10, 2015 3:37 pm
    j4570 wrote:I have a rebuilt original ST-70 that was upgraded to VTA specs.  I reused the original output transformers but used the upgraded VTA-70 power transformer.  I always run the cage with the screws snugged up holding it on (except when bias adjusting).  I have had no mechanical hum issues.
    Jason
    Do you have 60Hz ? It might be the difference, we have 50Hz here.
    Post by arledgsc Fri Dec 11, 2015 11:32 am
    On my ST-120 I held ferrous material close to the transformers while in operation (steady state) and does not appear to be any stray magnetic fields that attracts iron in any way. Not sure about power up but does not look like much an issue with the ST-120.
    Post by peterh Fri Dec 11, 2015 12:07 pm
    arledgsc wrote:On my ST-120 I held ferrous material close to the transformers while in operation (steady state) and does not appear to be any stray magnetic fields that attracts iron in any way.  Not sure about power up but does not look like much an issue with the ST-120.
    I would not expect the transformer to attract magnetic material, but i do expect it to
    induce vibration.
    Post by Guest Fri Dec 11, 2015 12:35 pm
    Post by peterh Fri Dec 11, 2015 3:03 pm
    PeterCapo wrote:Try the isolation mounts.  I used double isolation mounts on mine, and it runs smooth enough.
    It's not the transformer that hums, was the cover that vibrates due to the alternating forces that the
    mains transformer caused.
    Now when i have passsed the cover to a friend's homemade "thing" i have no hum.
    But i would like to try a non-magnetic cover anyday.
    j4570
    Post by j4570 Fri Dec 18, 2015 2:11 pm
    Peter,
    Yes, I'm in the US and I have 60Hz mains.
    You could solve that 50 HZ problem by relocating..........
    Just kidding.
    Hopefully you will get your wish one day.
    Jason
    DynakitParts
    DynakitParts
    Dynakit ST-70 Covers Empty Cover contributes to violent hum
    Post by DynakitParts Fri Dec 18, 2015 3:01 pm
    In review of everyone's reply (Thank you)...
    It appears that Peter's problem may in fact be due to the 50hz operation of the power transformer....Although, I have never had one complaint from our International customers, I think the choice of the word violently was a bit over the top. Violently would be my wife's reaction to finding me in bed with her (2) younger sisters...
    Merry Christmas to all...
    Kevin
      Current date/time is Fri Apr 19, 2024 8:33 am
