    VTA ST-70 enclosure
    bluerondo
    bluerondo
    VTA ST-70 enclosure Empty VTA ST-70 enclosure
    Post by bluerondo Sun Oct 05, 2014 2:11 pm
    I noticed a few custom enclosures other users have built for their amps and after doing some research I decided to try my hand at something. I found some red oak 2" pieces at the local hardware store. I had one requirement which was that it should easily slip on from the top so it can easily be removed for servicing. So far I have decided not to use any screws for fastening. The front panel was the hardest part, composed of three separate sections. All just wood glued together. The back has a thin piece similar to the top front piece. Next version will be very similar except I will use a single piece for the front panel and the center will be table routed out for a straight clean cut. Some higher feet under the chassis will raise the whole thing up a bit.
    I would be great to see what others have come up with.
    VTA ST-70 enclosure 15263089870_47defd3092_b
    Bill
    VTA ST-70 enclosure Empty Re: VTA ST-70 enclosure
    Post by corndog71 Sun Oct 05, 2014 2:40 pm
    That looks really sharp! cheers
    DynakitParts
    DynakitParts
    VTA ST-70 enclosure Empty Wood Enclosure
    Post by DynakitParts Sun Oct 05, 2014 3:14 pm
    I like it!
    Kevin
      Current date/time is Thu Mar 28, 2024 9:07 pm
