    Remote Volume Control in SP9
    Remote Volume Control in SP9 Empty Remote Volume Control in SP9
    Post by TMadden Thu Nov 20, 2014 6:58 pm
    I recently installed a remote volume control in my VTA SP9, just to see how it would work out.
    I was lucky enough to have a convenient spot to mount the board, I powered it with what was the
    power connection to the power-on indicator , removed the dropping resistor from the LED power indicator and
    connected that to the remote board. I then drilled a hole in the front panel for the IR receiver, and chamfered it, and mounted the IR receiver.
    Works great!
    Remote Volume Control in SP9 IMG_3745_zps892214d0
    dougmon
    dougmon
    Remote Volume Control in SP9 Empty Re: Remote Volume Control in SP9
    Post by dougmon Thu Nov 20, 2014 8:31 pm
    Cool! Could we see the front of the SP9?
    Does this mean that older VTA preamps can be retrofitted with remotes?
    Post by TMadden Thu Nov 20, 2014 8:46 pm
    If your preamp uses a potentiometer type volume control , like yours, sure. My SP9 has been subjected to a lot of changes, so it's a little rough around the edges, and it could use a good cleaning, but here's a pic of the front panel with the remote added:
    Remote Volume Control in SP9 IMG_3755_zps8add335d
    dougmon
    dougmon
    Post by dougmon Thu Nov 20, 2014 9:00 pm
    That is very cool. Thanks. What with the new monoblocks and the remote, it must almost be like early Christmas around your house.
    Post by TMadden Thu Nov 20, 2014 9:05 pm
    It's great fun when things work out as planned for sure!
    MexicoMike
    Post by MexicoMike Sat Nov 22, 2014 8:20 pm
    Neat! Where did you get the system (Pot + controller/remote)?
    Post by TMadden Sat Nov 22, 2014 8:54 pm
    All the components were sourced from eBay. The remote kit included an ALPS RK168 motorized pot but I substituted the RK27. The IR receiver , cable and connector were "borrowed" from a another remote kit.
    Post by peterh Sun Nov 23, 2014 3:51 am
    MexicoMike wrote:Neat!  Where did you get the system (Pot + controller/remote)?
    See https://dynacotubeaudio.forumotion.com/t2290-remote-control-for-preamp-from-china
    there is, on the first post, a still working link to such a beast.
    Post by TMadden Sun Nov 23, 2014 9:18 am
      Current date/time is Thu Mar 28, 2024 5:01 am
