    ST70 too bright...why?
    tygr1
    Re: ST70 too bright...why?
    Post by tygr1 on Mon Dec 22, 2014 9:42 pm
    OK, here's what I've got so far. With my (new) Fluke 27 I'm seeing 415v at the VTA board B+. Does anyone know if this is good, bad or indifferent?
    Just got the meter and haven't had time to take the amp out of my setup to check the main B+ voltage. I suspect my cheap meter wouldn't even read the 415 volts without showing an overload warning so my main B+ may be ok after all. Wall voltage right now is 121.3v.
    Post by peterh on Tue Dec 23, 2014 3:49 am
    If you are measuring voltages, please measure the ones mentioned on page 9 in the dynaco st70 manual,
    415V seems reasonable however.
    tygr1
    Post by tygr1 on Tue Dec 23, 2014 10:04 am
    PeterH, I'm seeing 384vac at pin 6 of the rectifier tube and 472vdc at pin 8. This is with 122.2vac at the wall.
    Post by peterh on Tue Dec 23, 2014 12:22 pm
    tygr1 wrote:PeterH, I'm seeing 384vac at pin 6 of the rectifier tube and 472vdc at pin 8. This is with 122.2vac at the wall.
    Seems very reasonable with that wallVoltage.
    Post by tubes4hifi on Tue Dec 23, 2014 6:56 pm
    Peter, and everyone,
    anyone who buys a VTA board from me or Bob gets full documentation, with voltage checks and schematics.
    B+ to the board should be around 380-400vdc after going thru the supplied 2.2K dropping resistor.
    All other voltages on the board are marked on the schematic.
    tygr1
    Post by tygr1 on Tue Dec 23, 2014 7:02 pm
    Thanks for that guys!
    PeterCapo
    Post by PeterCapo on Tue Dec 23, 2014 7:53 pm
    tubes4hifi wrote:Peter, and everyone,
    Understood. I had mentioned it because I was of the impression, perhaps mistakenly, that tygr1 bought the amp second-hand and that the documentation was not included.
    tygr1
    Post by tygr1 on Tue Dec 23, 2014 8:13 pm
    I did buy the amp already modded and do not have the documentation. So, much thanks to everyone who offered info!
      Current date/time is Sat May 26, 2018 8:15 am
