    Power supply resistor question
    colin86325
    Post by colin86325 on Sat Jan 03, 2015 6:09 pm
    I am trying to figure out what wattage the resistors are in my power supply.  The power supply uses 2 can-style capacitors (100-100uF, and 80-40-30-20uF).  I attached a diagram of the circuit but I'm not very good at this stuff, so please forgive the crude drawings.  i also attached a picture of the resistors.  What wattage is safe in this application?  I was thinking 2 watts, but wanted to ask.  This amp has SS rectification.
    Re: Power supply resistor question
    Post by Bob Latino on Sat Jan 03, 2015 6:22 pm
    Hi Colin,
    I believe that those original Dynaco 22K and 6.8K resistors were two watt. If you want to replace them, two watt resistors would be fine ..
    colin86325
    Post by colin86325 on Sat Jan 03, 2015 10:46 pm
    Bob, thanks for the quick reply!
    Have you seen a similar modification with the two chokes?
    I haven't really been able to enjoy the amp yet because of the 60Hz hum that I guessed is from failed power supply caps. Finally I have found some time to actually do some soldering, so I hope to keep plugging away. Once I get it working well with the stock Dyanco board I hope to then get the VTA board to compare with.
    Post by Bob Latino on Sun Jan 04, 2015 6:09 pm
    The VTA ST-120 uses TWO CHOKES because it draws noticeably more current than the ST-70. IMHO, you don't really need two chokes in any ST-70 .. Dynaco shipped out about 350,000 ST-70's with one choke and those chokes rarely ever go bad. The original C-354 was rated at 200 milliamps and evidently those chokes were not stressed out much. I use the Triad C24-X chokes in all the VTA amps. They are the same size as a C-354 choke but are rated at 240 milliamps. The VTA ST-70 uses ONE choke and the VTA ST-120 and M-125's use TWO chokes. The use of two C24-X chokes would raise the dual chokes rating to 480 milliamps current draw. 480 milliamps is far beyond what either a VTA ST-120 or a VTA M-125 can draw during normal use. As a test one time I ran a pair of M-125's at 75 milliamps per tube current flow for 5 hours. Four tubes (4 X 75 milliamps) would equal 300 milliamps and the three driver tubes use maybe 10 milliamps each. So I am guessing about 330 to maybe 350 (when the music is playing loudly) milliamp current draw for those 5 hours. The amp got a little warmer than normal (checked with an infrared thermometer) but nothing undesirable happened ..
    colin86325
    Post by colin86325 on Sun Jan 04, 2015 8:24 pm
    Ok, thanks for clearing that up. I think for now I will keep the second choke in place as it probably can't hurt anything.
      Current date/time is Thu Apr 19, 2018 3:12 pm
