by Cubdriver Thu Feb 12, 2015 5:56 pm
The reason you see a flash is because with the short 'off' time, you're effectively doing a hot start.
When the power is first turned on, the filter cap looks pretty much like a short to the rectifier, drawing as much current as the tube can supply, with this current draw fairly rapidly falling off as the cap charges and the voltage across it rises. The tube provides something of a 'soft start' to charge the cap, as it also takes a few moments for the current flowing in the tube to increase as it heats up. The reduced current capability of the tube coincides with the time that the cap is trying to draw the maximum, and between the two things the cap is brought up to its charged state while the current flowing in the tube is limited by its not being fully up to temperature.
If the amp is turned off for a short time (typically less than a minute or two), then turned back on again, the filter cap has time to be discharged (the output tubes are hot and conducting), and does its 'short' act when power is reapplied. The rectifier tube begins conducting more quickly than normal as it's still warm, and the output tubes are likely to still be in a conductive state as well, adding to the 'short' load on the rectifier. Lightning ensues. (The output tubes take longer to heat up from a cold start due to their construction, and thus the rectifier doesn't see them as a load on initial cold power up - it gets the filter cap charged, and as it's finishing that job the outputs start to conduct and everything transitions easily.)
The series diodes don't prevent this because it's a current draw issue, rather than reverse voltage.
To prevent it from happening, if you accidentally or intentionally turn the amp off, let it sit for five minutes or so before turning it back on to permit the tubes to cool off somewhat. Doing so will go a long way to make the rectifier happy.
-Pat
