+2
skriefal
Cubdriver
6 posters
    M125 construction FINALLY started...
    Cubdriver
    Cubdriver
    M125 construction FINALLY started... Empty M125 construction FINALLY started...
    Post by Cubdriver Tue Feb 24, 2015 11:53 pm
    I bought 'em back in November, and they've been waiting patiently for me to get my act together.  As of last night, the driver boards have been assembled.  I made a time lapse video of the assembly (including my screw ups, like mounting all the pots on the top of the boards at first; partway through I moved the balance ones to the underside where they're supposed to be).
    I did the same thing with the big metal PIO coupling caps that I did on the ST-70 - insulating the bodies with clear head shrink tubing (folding the extended ends down against the flat ends of the cap while they were still warm and pliable this time), and tie-wrapping the caps to self adhesive anchors stuck on the board to support them and take strain off of the leads.
    I'll attempt to embed the time lapse here; if this fails I'll put in a link.  Some pictures of the finished board will follow.
    -Pat
    M125 construction FINALLY started... M-125%20driver%20boards-L
    Board assembly time lapse
    Cubdriver
    Cubdriver
    M125 construction FINALLY started... Empty Re: M125 construction FINALLY started...
    Post by Cubdriver Tue Feb 24, 2015 11:58 pm
    And here are some images of the finished boards:
    Bottom oblique:
    M125 construction FINALLY started... IMG_8020-L
    Cap end detail:
    M125 construction FINALLY started... IMG_8028-L
    Tiewrap anchor detail:
    M125 construction FINALLY started... IMG_8035-L
    Now to get ambitious and powder coat the transformer end bells...
    -Pat
    skriefal
    skriefal
    Post by skriefal Wed Feb 25, 2015 12:29 am
    Nice!
    BNR_1
    Post by BNR_1 Wed Feb 25, 2015 10:06 am
    Nice job.....btw great photos. Looking forward to seeing your progress.
    Cubdriver
    Cubdriver
    Post by Cubdriver Wed Feb 25, 2015 1:00 pm
    Thanks.  You've gotta love a tripod for nice clear close up photos.
    I have to say that I'm pleasantly surprised by how nicely the extended parts of the clear heatshrink folded down over the ends of the caps.  It looks almost as if it was meant to be, and was surprisingly easy to do while it was still hot and pliable - I just nudged it into place with my fingertips, and when it cooled and stiffened, it stayed nicely.  Next time I'll have a pencil or the like (something that doesn't feel pain from being burned, unlike my fingertips!) handy to do the forming.
    -Pat
    Frank111
    Post by Frank111 Wed Feb 25, 2015 2:16 pm
    My M-125 kits are on their way, so I'll be following your postings closely! I appreciate your comments on mistakes you corrected with assembly. That's going to make me more aware of things as I proceed with the build. This is great timing!
    Frank.
    Cubdriver
    Cubdriver
    Post by Cubdriver Wed Feb 25, 2015 3:00 pm
    Frank, the key is to simply read the assembly instructions thoroughly.  I was happy to finally be building them, and in light of that not reading as carefully as I should have.  Bob's instructions are very good, but you need to actually read the WHOLE step, not just the beginning and end!
    The balance pot instruction step notes that you need to check prior to installing them to be certain that they're centered in their adjustment range (the brief appearance of the DMM in the time lapse is me verifying this), then notes that they are to be installed on the underside of the board and soldered on the top, and finally that the adjustment is not to be further touched unless you have a signal generator and know what you're doing.  I followed the first part, missed the second and made a mental note of the third.  And put the pots on the top of the board.  And THEN realized what the second part of the step said.  D'oh!
    I debated just leaving them on top and sealing the adjustment screw with some nail polish, but then decided that I should do it right and move them to the correct location.
    In short, take your time, read the directions, and follow them.
    -Pat
    Post by Guest Wed Feb 25, 2015 4:43 pm
    there is something SERIOUSLY wrong with those photo's!!!!!!!!
    It is WAAAAAYYYYYY too clean and tidy...I could never work in those conditions!!!!!..... Shocked
    BNR_1
    Post by BNR_1 Wed Feb 25, 2015 5:02 pm
    Are those adhesive anchors over pcb traces? If so do you know if they ever need to be removed are they going to pull/damage the trace?
    Post by Guest Wed Feb 25, 2015 5:21 pm
    BNR_1 wrote:Are those adhesive anchors over pcb traces?  If so do you know if they ever need to be removed are they going to pull/damage the trace?
    they should absolutely not do any damage what so ever to the pcb or traces. Might get a bit messy if ever one needs to remove them, but the chance of that happening is indeed very slim.
    So it is safe to do so.
    Post by sKiZo Wed Feb 25, 2015 5:34 pm
    Dressing your sockets? The VTA boards have copper on both sides just for that - makes for a much sturdier socket, which is a good thing if you're a roller ...
    M125 construction FINALLY started... Dressed-sockets-top
    Ditto for all the other components ...
    Cubdriver
    Cubdriver
    Post by Cubdriver Wed Feb 25, 2015 5:36 pm
    MontanaWay wrote:there is something SERIOUSLY wrong with those photo's!!!!!!!!
    LMAO - please note that the photos are VERY closely framed - I merely pushed the pile-o-crap out of the immediate area so it wasn't in the pics.
    This more to your liking, Montana?
    M125 construction FINALLY started... IMG_8049-L
    M125 construction FINALLY started... IMG_8052-L
    -Pat
    10-E-C
    10-E-C
    Post by 10-E-C Wed Feb 25, 2015 5:40 pm
    I thought I saw a Puddy Cat!!!!!
    Cubdriver
    Cubdriver
    Post by Cubdriver Wed Feb 25, 2015 5:41 pm
    They are over traces, but as Montana says, they can be removed without damaging anything.  I did it several times on the ST-70 board because I put them on before fitting the board, then discovered that I needed to shift the caps back due to mechanical interference under the chassis.  They're held on with foam tape - slice through the tape to separate the plastic mount from the board, then, using fingernails, orangewood spudgers and the like, the remaining foam and adhesive can be rubbed off the board with a few minutes of effort.
    -Pat
    Last edited by Cubdriver on Wed Feb 25, 2015 5:45 pm; edited 1 time in total (Reason for editing : Removed double quote)
    Cubdriver
    Cubdriver
    Post by Cubdriver Wed Feb 25, 2015 5:43 pm
    sKiZo wrote:Dressing your sockets? The VTA boards have copper on both sides just for that - makes for a much sturdier socket, which is a good thing if you're a roller ...
    Dachh!  I *thought* I'd hit and re-flowed all the top connections for the sockets; apparently I missed.  Thanks for noticing, Skiz - will add some solder to them.
    -Pat
    Edit to add - I just realized that's one of the ST-70 board pics. I *did* hit the tops on this set of boards. Will perhaps revisit the ST-70 at some point, but it's working fine now (can be seen sitting on top of the bench) so that may be a future project.
    Cubdriver
    Cubdriver
    Post by Cubdriver Wed Feb 25, 2015 5:44 pm
    10-E-C wrote:I thought I saw a Puddy Cat!!!!!
    Yup, one of the two fur generators, absconding with a twist tie...
    -Pat
    Post by Guest Wed Feb 25, 2015 5:49 pm
    -Pat
    aaaaaahhhhhhh...yesssssss...now I feel more at home!!!!! What a Face
      Current date/time is Thu Mar 28, 2024 6:02 am
