I just got ahold of an ST-70A, and it has the spanner screws holding the bottom plate on. Is there an easy way to get these out without having to buy a bit - seems the bits are available in several sizes and I'd hate to make the drive to find one then find it's the wrong size. I suppose I could just drill it out.
spanner screw removal
Re: spanner screw removal
You need a pin spanner wrench to get those out .. Check the one on Ebay at the link below ...
Pin spanner wrench on Ebay ..
daveshel- Posts : 169
Thanks, Bob. Kinda pricey for two screws though.
Maintarget- Posts : 227
Its a PITA but you can use two steel dowels, Pins or drill bits and a crescent wrench to remove them IF you have the room to maneuver or just send the 11 bucks and be done with it
j beede- Posts : 473
Do you plan to reuse the screws? If not... I use a Dremel with two carborundum cutting wheels stacked to cut a screwdriver slot. Surround the area with blue tape to avoid nicks in case the cutting wheel breaks or bucks.
Alternative: Harbor Freight sells a pin wrench for removing watch covers for a couple dollars--not sure it if closes down enough for that screw though. HF also sells snap ring pliers that will work. Again, blue tape to avoid damage when the pliers "de-slot".
GP49- Posts : 792
- Post n°6
I have been able to improvise. Using steel wire in the correct diameter to fit the holes, I bend a U-shape. I can use pliers to grip the curved part of the "U" so that the ends stick out and can be used to turn the screw.
I learned this from repairing cameras for a hobby. They sometimes use this kind of screw rather than slotted types, for appearance reasons.
