    Recent DIY project a new Turntable
    tiguan
    Recent DIY project a new Turntable Empty Recent DIY project a new Turntable
    Post by tiguan on Tue Mar 03, 2015 7:30 am
    As it was asked in another topic about some details of my recent project, to not to disturb Whats your turntable topic it would be better a separate topic for whom will be interested.
    Actually I started with upgrading my existing turntable "Rega P3-24 with external TT PSU".
    Previously I replaced subplatter, dual pulley, 2 silicone belt and was thinking to replace counterweight, put a "on the fly VTA adjuster" and replace internal wiring. When looking thorough the web for good alternatives for those components, saw many good DIY projects and after 2 months of investigation ended with making a new Turntable.
    My guideline items were following;
    - to use existing components of Rega. Because when I was going to change a main component it have affects on others such as changing platter with a heavier would affect rotation and speed, would need a stronger motor so it goes and therefore decided to continue step by step. To upgrade later the platter, motor, bearing structure.
    - should be a flexible design.
    - available for 2 arms preferably a 12" arm as a second
    - should have a warm outlook of course would be wooden based
    - should comply with damping and decoupling requierments.
    - should have a separate structure for motor without relation with any part of turntable
    There are many good projects on the web. But as for damping and body I believe the best source is Audioqualia
    First I tought to use solid wood with good damping characteristic such as Ironwood, Olivewood (oiled) as body and found IPE (African Ironwood). But after bringing to home in room temperature after 1 week it started to have some cracks (even the seller told that is was dried already)
    So I turned my way to processed wood. It was impossible to find either Panzerholz or Permali which have perfect damping factor. I decided to go to a composite structure. Main parts of the composite structure is 4 layer 18 mm baltic birch pylwood and isophaltic polyester resin. Isophaltic based polyester resin have very good damping characteristic as well and lead to increase the weight.
    I established a box from plywood layers cut at CNC. Glued together filled with isophaltic polyester resin and lead balls.
    Now I am sandpapering the bodies. Trying to decide oil and varnish. Making some samples with IKEA beewax varnish, tungoil, urethane based varnish etc.
    Feets will be sorbothane and spike combination. I already suplied counter weight as tecnoweight and Michell on the fly VTA adjuster.
    Recent DIY project a new Turntable 039ce898fefe72e6c5f3b708f9e483c5
    Recent DIY project a new Turntable 1bae636ca921883744c88ed6e6ad4f85
    Recent DIY project a new Turntable A844246d97f4ffaaac2f51a8269cdafa
    Recent DIY project a new Turntable A744a45570b72b2a0d0358ddda2698ae
    Recent DIY project a new Turntable 1a81f00924979d8adf3fd073b4d9c9ad
    Recent DIY project a new Turntable 8ae49d4726175605b8127ea8625130a0
    Recent DIY project a new Turntable 7accac283763a52320e2ed09071a7e91
    Recent DIY project a new Turntable Empty Re: Recent DIY project a new Turntable
    Post by arledgsc on Tue Mar 03, 2015 11:21 am
    Nice project and well done. In the acoustic guitar world manufactured woods and urethane are known for damping properties versus solid woods and lacquers like nitrocellulose. So composite wood is a good choice and will be very stable over time.
    tiguan
    Post by tiguan on Fri Mar 27, 2015 4:54 am
    I found veneer sheets made from ebony and iroko burl. Upper faces of both bodies I plan to veneer.
    I plan to use first and last row ebony between them iroko burl .
    I sprayed water to show how it will look like after varnish.
    Recent DIY project a new Turntable 14a9a630e95e2c8785736c61297bbde9
    Recent DIY project a new Turntable 8164bdc802e76b203c7395e26ec66ca3
    I have aligned joining edges. And glued veneer on lower big platform.
    Upper body will follow.
    Recent DIY project a new Turntable 4f126f597889561281638e28cb3ba752
    tiguan
    Post by tiguan on Mon May 04, 2015 9:00 am
    I have finally completed my new turnta le.
    Photos can be reached here.
    DIY TURNTABLE
    TN Allen
    Post by TN Allen on Mon May 04, 2015 10:01 am
    Nicely done! I looked to find information on the motor you are using, and may well have overlooked it. Could you tell me what the motor is? Thank you.
    Post by audiobill on Mon May 04, 2015 11:49 am
    Wow, that's beautiful!!!
    tiguan
    Post by tiguan on Mon May 04, 2015 12:20 pm
    TN Allen wrote:Nicely done! I looked to find information on the motor you are using, and may well have overlooked it. Could you tell me what the motor is? Thank you.
    Thanks TN Allen, I had a Rega P3-24 with an external TTPSU and used all parts accept body...
    İ used premotec motor, power board and TT Psu of rega. But for the future second motor on the opposite is reserved already.
    In the future the upgrades will be;
    -second motor
    -new platter
    -and 12 inch unipivot second arm
    tiguan
    Post by tiguan on Mon May 04, 2015 12:22 pm
    audiobill wrote:Wow, that's beautiful!!!
    Thank you audiobill
    bluerondo
    bluerondo
    Post by bluerondo on Mon May 04, 2015 10:18 pm
    Wow! That really is something! I can't imagine building anything like that.
    Thanks for sharing.
    tiguan
    Post by tiguan on Wed May 06, 2015 3:41 pm
    bluerondo wrote:Wow! That really is something! I can't imagine building anything like that.
    Thanks for sharing.
    Thanks for your kind words, I inspired from many DIY projects and tried to combined the logical parts based on my humble engineering experience,
    Hope it will help others who wants to enter such a way,
    any question about what, how and why, I can try to clarify.
      Current date/time is Fri Dec 06, 2019 7:51 am
