swapped out existing el34 in my st70 with a new matched quad of shunguang sp. EL34-B.
Had a difficult time seating the tubes next to the xfmrs. Had to rock and roll them around quite a bit to seat them properly.The front ones went in very easy? The tube pins seemed slightly splayed outward and pin tips seemed a little rough compared to the tubes that came out.Can the tube pins be lightly dressed with emery sp.cloth and dressed with a contact enhancer?Also,is it appropriate to bias the EL34-B a little lower to start,then slowly raise bias as tubes burn in over time? Thanks Varlagger
