My Dyna 70 with the VTA mods went into service in 2020, and have been really happy with them. I started with the first amp as a traditional stereo amp while I built the 2nd one. Then used both amps in a vertical bi-amp configuration, along with an active subwoofer. Spectacular soundstage, great clarity, and overall a really nice situation. However...nothing is perfect....
My speakers have an 8" Focal kevlar woofer in a transmission line, and a 5" Focal kevlar midbass driver mated to a Seas tweeter. They were originally in a much smaller space, and have always had nice natural sounding bass. The move to a considerably larger room left the 8" woofers sounding a bit smaller in that space. Adding an active subwoofer helped give more deep bass, but didn't help the mid and upper bass. Turning the variable low-pass crossover of the sub to a higher frequency just made it sound muddy in the vocals and midbass, so I tend to keep it set right at 50hz and let it augment whatever bass I had.
The speakers have a separate input for each driver, which is conducive to bi-wiring, bi-amping, or tri-amping. In an effort to boost the output of the 8" Focal woofers in the T-line of the main speakers, I just recently added an integrated Kenwood amp plus an active low pass crossover to drive just the 8" woofers, and bypassed the stock passive low pass filter, running them from 80hz down. Then hooked up the powered sub at ~ 50hz down from the integrated amp as well. This essentially makes it a horizontal bi-amp configuration with mono blocks up top (monoblocks are inherently a vertical bi-amp configuration). So "hybrid" bi-amping if you will.
This setup gives a separate volume knob for both the woofer and the sub from 80hz down, plus variable gain control of sub at 50hz, plus the option of contouring the bass output at ~ 100 hz with the bass knob of the Kenwood... all fed by the master volume of my Lazarus tube preamp. I'm loving all the options and flexibility it gives me to dial in the low bass, mid bass, and upper bass without muddying up male vocals. It also changed the load that the Dyna/VTA 70s to 8 ohms, and they sound cleaner from the lower mids on up, which was unexpected, but always welcome.
Adding a solid state integrated amp to the bass is a great way to add bi-amping to a system if your speakers have dual (or triple) inputs. Your results will vary depending on your speakers, crossover frequencies, system, etc. The addition of the old Kenwood and an automotive active crossover (with a 12v wall wart) has been one of the best $100 improvements I've done in 40 years of messing with this stuff. But, never being one to leave things alone, I tried some Tung Sol 7581A output tubes while I was at it, and have been really enjoying those. Last, and probably least, was the addition of some solid copper input jacks for the mids and tweeters. All in all...it's time to sit back and enjoy the fruits of my labor for a while.
Last edited by knotscott on Thu Dec 21, 2023 7:08 pm; edited 9 times in total (Reason for editing : update)
