I have an sp 9 with a ph 10 phono stage witch uses 12ay7... my question is can i use some of my vintage NON 12at7 bent wing blackplates in place of the stock tube....i believe the 12at7 is 60 mu and the 12ay7 is 45...BOB B
12at7 vs 12ay7
peterh- Posts : 1823
Re: 12at7 vs 12ay7
Nope, this is dissimular tubes.rfbro wrote:I have an sp 9 with a ph 10 phono stage witch uses 12ay7... my question is can i use some of my vintage NON 12at7 bent wing blackplates in place of the stock tube....i believe the 12at7 is 60 mu and the 12ay7 is 45...BOB B
12ay7 is more like a 12ax7 / 5751 type of tube.
( i know that guitarfolks happily mix these tubes, but they are searching for distorsion)
Roy Mottram- Admin
Re: 12at7 vs 12ay7
the PH10 phono stage is optimized for the 12AY7 tubes, any other type will throw of the RIAA EQ completely
Jim McShane- Posts : 237
Re: 12at7 vs 12ay7
What Roy said! And also it's more than just the tube's mu that is important. Transconductance and plate resistance also factor in, and in a phono stage these values are all important.
