+5
skriefal
Pat R.
Zimmer64
9 posters
    FREE internet radio at higher bit rates
    FREE internet radio at higher bit rates Empty FREE internet radio at higher bit rates
    Post by Bob Latino Mon Feb 23, 2015 8:54 pm
    I have noticed a trend towards internet radio streams having higher and higher bit rates that are now near CD quality and are FREE .... These two are 320 KBps @ 44.1KHz
    Check out > Free classic rock radio Hit the "Stream URL" link inside you click on to listen ...
    and > 50's Rock and Roll  Hit the Listen Live button when you get to the web site
    If you find any other 320 KBps or higher FREE internet radio links post them in this thread ...
    Zimmer64
    Zimmer64
    FREE internet radio at higher bit rates Empty Re: FREE internet radio at higher bit rates
    Post by Zimmer64 Tue Feb 24, 2015 3:31 pm
    Three more stations right here: http://www.linn.co.uk/radio#linn-radio
    Michael
    Pat R.
    Pat R.
    Post by Pat R. Thu Feb 26, 2015 2:40 pm
    Kinda makes you wonder what use we have for a Tuner now? Loaded with commercials and a compressed signal to boot..
    Post by sKiZo Thu Feb 26, 2015 4:12 pm
    No such thing as "free" internet out here in the sticks. It's amazing how fast my 5gig per month limit goes away if I start listening to radio or pulling down video. I'm tickling the limit right now and it's a short month!
    (mutter mutter)
    PS ... I'm on ATT wireless. They've been advertizing that new rollover data option thing to "show their appreciation", but apparently that doesn't apply to wireless internet. I gave them a call and mentioned that I'm currently feeling a bit under-appreciated ...
    (grumble)
    * Don't forget ARCHIVE.ORG for some real nice downloads. Not streaming, but still an interesting selection of music in high resolution mp3 or FLAC.
    skriefal
    skriefal
    Post by skriefal Fri Feb 27, 2015 1:29 am
    Radio Paradise has a 192k Ogg Vorbis stream. This should be superior to a 192k MP3 stream, but I'm not sure whether it'll match a 320k MP3 stream. Links to the streaming options are available at:
    http://www.radioparadise.com/rp_2.php#name=Listen
    Post by Tube Nube Fri Feb 27, 2015 8:55 pm
    I womder if something like drop box or some other cloud-thingy could be utilized so a group of friends on a bulletin forum could "lend" their digital files to others...
    Post by sKiZo Fri Feb 27, 2015 10:54 pm
    That's where Digital Rights Management rears it's ugly head.
    I know Amazon has a specific license embedded in every MP3 you purchase from them, and it'll only play on your cloud. Your log in is also assigned to a specific computer. Not sure how you'd attach any portable devices as I never tried it.
    Re-encoding the file doesn't strip the tag, but it looks like you can manually delete it using a tag editor ...
    There also, my paltry 5gig monthly wouldn't last long if I actually used their cloud for anything other than download the purchased files to my server.
    Post by Tube Nube Fri Feb 27, 2015 11:05 pm
    Drat! Everything is harder than it looks! How nice it would be in this digital, connected ge if there were a digital conmected version of "here, borrow this tpe of mine and see what you think."
    i've got 300+cds ripped to a hard drive for wifi broadcast through my squeezebox to my (still fantastic tubes for hifi) stereo.
    I'm just guessing none of you is going to order music of the renaissance on the Dorian label, unless you have a chance to hear it first...
    Though I do understand that hering it free can and does short circuit the purche part of the theory.
    skriefal
    skriefal
    Post by skriefal Fri Feb 27, 2015 11:07 pm
    Tube Nube wrote:Drat! Everything is harder than it looks! How nice it would be in this digital, connected ge if there were a digital conmected version of "here, borrow this tpe of mine and see what you think."
    It's called Youtube. But you'll have to settle for less than audiophile quality.
    Post by Tube Nube Fri Feb 27, 2015 11:22 pm
    I reject You Tube as a bald faced lie! It should be YouMicrochip! There's none of our beloved tubes in it!
    skriefal
    skriefal
    Post by skriefal Fri Feb 27, 2015 11:28 pm
    Ha.  Less than audiophile quality and no tubes (on their end)!
    batman7349
    Post by batman7349 Sat Mar 14, 2015 3:44 pm
    What is the preferred method to connect the PC to your system? Straight out of the onboard audio, a high end audio card, or a USB DAC?
    Post by Bob Latino Sat Mar 14, 2015 4:34 pm
    batman7349 wrote:What is the preferred method to connect the PC to your system? Straight out of the onboard audio, a high end audio card, or a USB DAC?
    You will get better output by using an outboard DAC from the digital out on your computer or using a USB DAC. I think a higher end audio card might not be as cost effective as a USB DAC or the digital out to a normal DAC.
    We have an older thread somewhere (that I cannot find) about inexpensive DAC's like the Schiit modi (now the modi2) Almost any outboard DAC will give better sound than the line level audio out on your computer ..
    skriefal
    skriefal
    Post by skriefal Sat Mar 14, 2015 4:48 pm
    Consider a simple USB DAC. Such as the HiFimeDIY unit based on the ESS 9023:
    http://hifimediy.com/DACs/ready-made-dacs/U2-DAC
    They have other models, but this one is preferable because it will accept 88.2kHz input over USB (in addition to 44.1, 48, 96kHz). Many other similar models from HiFimeDIY and elsewhere won't accept 88.2kHz due to USB receiver chip limitations.
    Post by sKiZo Sat Mar 14, 2015 5:23 pm
    Big fan of the Maverick TubeMagic D1+ here ... I got two of em.
    I have the OPA627 op amps upgrade installed, and use a 1952 WE 2C51 or Tesla 6CC42, both of which play well with the tube set in the ST120.
    FREE internet radio at higher bit rates Maverick-d1-we396a
    The USB out uses the Tenor chipset, which to me is outstanding. Very smooth and refined. Tops out at 96/24, but I prefer that to the SPDIF optical or coaxial out which can do 192/24, but sounds a bit sterile to me.
    Only issue with USB is that there can be a LOT of competition for computer resources. I had some mildly annoying dropouts and ticking on the latest HTPC build. Come to find out, it was my wireless keyboard and mouse. Solution was to install a USB expansion board that creates it's own channel and is hooked directly to the power supply instead of running through the standard bus. Zero noise and improved sound all around. Best $20 upgrade I've made.
    The D2 works well too I'm told, but doesn't have the analog throughput of the D1+. I plug my turntable into that via an external stage so I can get some of that sweet toobie goodness on vinyl too.
    skriefal
    skriefal
    Post by skriefal Sat Mar 14, 2015 5:26 pm
    The Tenor chipset is one that can't handle 88.2kHz, IIRC. But that may not be a problem if you'd don't rip SACDs or purchase/download SACD-sourced content from HDTracks.com.
    batman7349
    Post by batman7349 Sat Mar 14, 2015 6:18 pm
    Got some good answers here. I'll research the modi2, ODAC, and the Tube Magic. I guessing price wise I'll end up with the modi or ODAC. The only thing keeping me away from the Hifimediy is the lack of RCA outs.
    zx
    Post by zx Sun Mar 15, 2015 9:49 am
    Can someone say... if thay make a box that well give me a digital output from my laptop..  so I can go in the Rca digital input on my krell D/A?......the linn radio is best sound yet
    thanks for the site Bob.......................
    Post by Maintarget Sun Mar 15, 2015 10:22 pm
    A USB DAC is good for low cost entry level however they all have limitations that you will soon discover on your own especially if you like to crank it up, I have a Schiit Gungnir DAC with USB2 port at $800.00 great value IMHO
    Let us know what you end up with and review.
      Current date/time is Thu Mar 28, 2024 9:43 am
