    So, How do you open up the Pas3 Series 2 pre amp.
    USMC_Spike
    Post by USMC_Spike on Sun Mar 15, 2015 1:06 pm
    I've got the three screws on the rear panel removed
    which should let the chassis or cover slide out.
    It doesn't.
    What am I missing?
    Recall this is the reissue PAS3, the Series 2.
    Re: So, How do you open up the Pas3 Series 2 pre amp.
    Post by peterh on Sun Mar 15, 2015 1:33 pm
    USMC_Spike wrote:I've got the three screws on the face plate removed
    It doesn't.
    What am I missing?
    3 screws on the faceplate ???? There is no screws on the original faceplate.
    Is this something different then dynaco pas3 as described in dynaco's manual ?
    a pas3 is opened via the 4 screws on the shortsides, then both bottom and top cover is ready to pry out.
    USMC_Spike
    Post by USMC_Spike on Sun Mar 15, 2015 3:17 pm
    peterh wrote:
    USMC_Spike wrote:I've got the three screws on the rear plate removed
    which should let the chassis or cover slide out. My bad.
    What am I missing?
    Series II, series 2 - It is the reissue.
    Screws on the back panel.
    Post by peterh on Sun Mar 15, 2015 6:21 pm
    What am I missing?
    One learns each day ! Thanks!
    Post by Bob Latino on Sun Mar 15, 2015 6:35 pm
    In 2010 I made a post about the PAS-3 Series II preamp with some photos and a schematic .. It is at the link below
    PAS-3 Series II
      Current date/time is Mon May 21, 2018 1:25 am
