    Dynaco A-10 recap
    gatchaman
    Dynaco A-10 recap Empty Dynaco A-10 recap
    Post by gatchaman Sun Apr 05, 2015 8:35 am
    Hi all,
    I just scored a pair of Dynaco A-10's. I have been searching for a good pair for a long time, and now I finally scored a mint pair. I want to recap the crossovers, but I can't read the values on the capacitors anymore. Can someone help me? (I have no equipment to measure the values myself.)
    Kindest regards, Marlon.
    Dynaco A-10 recap Empty Re: Dynaco A-10 recap
    Post by Kentley Sun Apr 05, 2015 9:08 am
    gatchaman wrote:Hi all,
    I found this post on AudioKarma and it appears to come from a reputable poster. Cheers.
    "A brief visit from a very vintage Dynaco A 25 and an A 10
    I've recently had the privilege of restoring a pair of each of these. The A 25 proved to be a particularly pleasant surprise. It proved to be a very early version with Scanspeak Drivers and the FG stuffed vent located ABOVE the tweeter (see pics). The A 25 had a conventional crossover with 6 resistors and one 8 uF Jensen NPE cap. I replaced the cap with a Sonicap 8 uF, cleaned the rotary switch and left the original resistors intact.
    The rotary switch forms a conventional 2 resistor L-pad combining a varying series resistor (depending on switch position) with a 10 ohm parallelresistor. The resistors are 2.2, 4.4, 6.6, 8.8 and 11 ohms. The middle "normal" switch position utilizes the 6.6 and 10 ohm parallel resistor resulting in a 4 ohm resistance upstream of the tweeter. The other positions result in 1.8 ohm, 3.06 ohms, 4.7 ohms and 5.22 ohms. Each click of the rotary switch changes the SPL response about 2 dB.
    The cabinet was lined with thick rock wool-like batting and two extra layers loose under the woofer the length of the cabinet. The woofers were hard to remove due to assembly with a black, tar-like substance that remains to this day extremely sticky.
    When the work was completed, I took some measurements. The A 25's tweeter rolled off at about 10 kHz as shown here http://www.audiokarma.org/forums/sho...=425850&page=2.
    The A 10 also had Dynaco drivers. The cabinets had two batts of yellow FG. The crossover was more complex, consisting of an 8 uF cap, 5 ohm series and 8 ohm parallel resistor in the tweeter circuit. The woofer had a 4 mH series wired air core inductor and 24 uF parallel cap. The woofer cap was replaced with Dayton caps and the tweeter cap was another Sonicap cap. i have the speakers for a few more weeks. Let me know if you have any questions or need any further info. The A 10 HF roll off started at about 10 kHz also (see below), but at a steeper rate than the A 25. Its bass response was also not as good as the A 25.
    gatchaman
    Post by gatchaman Sun Apr 05, 2015 9:13 am
    Thanx a lot, Kently! This is what I needed! I am going to see if I can find the same values and start the recap.
    Post by Kentley Sun Apr 05, 2015 9:18 am
    gatchaman wrote:Thanx a lot, Kently! This is what I needed! I am going to see if I can find the same values and start the recap.
    It is of interest to me because I plan to do the same for some B&W relics I own. So please post your before/after impressions.
    Do you happen to be acquainted with a musician/producer in The Hague named Wim Oudijk? He's a friend of mine.
    gatchaman
    Post by gatchaman Mon Apr 06, 2015 3:10 am
    I am not acquainted with Wim Oudijk, but his name is familiar to me. Thanx again for the help.
      Current date/time is Fri Apr 26, 2024 7:31 am
