    ST-120 Amp ESl Capacitors
    geode
    ST-120 Amp ESl Capacitors Empty ST-120 Amp ESl Capacitors
    Post by geode on Mon Apr 20, 2015 4:25 pm
    The amp kit has three film caps in the values of 1.0uF, .1uF, and .01uF. All three are connected in parallel. Can I use one 1.5uF Film cap rated at 600VDC instead of the three. I have several good PolyPro film caps on hand. Anybody see any problems upping the values to 1.5uF for this ESL cap.
    ST-120 Amp ESl Capacitors Empty Re: ST-120 Amp ESl Capacitors
    Post by corndog71 on Mon Apr 20, 2015 4:41 pm
    I think just a 0.1uF would be adequate. It's just a bypass cap.
    geode
    Post by geode on Mon Apr 20, 2015 5:57 pm
    corndog71 wrote:I think just a 0.1uF would be adequate.  It's just a bypass cap.
    Thanks Corndog. So, the 1.5uF wouldn't be a problem. I have these caps and am itching to install them somewhere. I'm also chasing a low level hum in the left channel only. The hum is constant and isn't influenced by the attenuator. I'm thinking some wire might need re-routing. Already moved all the tubes around.
    Post by Bob Latino on Mon Apr 20, 2015 8:09 pm
    geode wrote:The amp kit has three film caps in the values of 1.0uF, .1uF, and .01uF. All three are connected in parallel. Can I use one 1.5uF Film cap rated at 600VDC instead of the three.  I have several good PolyPro film caps on hand.  Anybody see any problems upping the values to 1.5uF for this ESL cap.
    Yes - you can ...
    The newer VTA ST-120's (and M-125's) now have just a single 1.0 uF @ 630 volt ESL bypass cap. The two smaller caps were found to not really be necessary. The purpose of the ESL cap is to act as a "bypass cap" for the high voltage system. This cap gives the high voltage system a low impedance path to ground and helps break up any resonances in the larger caps.
    geode
    Post by geode on Mon Apr 20, 2015 10:35 pm
    Yes - you can ...
    Thanks Bob. Just checking to be sure.
      Current date/time is Tue Jul 16, 2019 9:23 am
