+3
zx
Frank111
7 posters
    Interpreting Tube Matching
    Frank111
    Interpreting Tube Matching Empty Interpreting Tube Matching
    Post by Frank111 Thu Apr 30, 2015 9:08 am
    What are the important parameters to know in tube matching? The 8 Tung-Sol KT-120's came with numbers on the box from the factory as well as an additional sticker with more numbers on it.  One was Gm and another was IP. Probably other info too. I'm trying to determine what's important when matching up tubes on the M-125.
    Thanks!
    Frank111
    zx
    Interpreting Tube Matching Empty Re: Interpreting Tube Matching
    Post by zx Thu Apr 30, 2015 9:23 am
    http://www.mcshanedesign.net/tubes.htm
    Great info on tubes...........if you did not get your tubes from him?
    Thanks for the site Bob.................
    Post by peterh Thu Apr 30, 2015 9:46 am
    Frank111 wrote:What are the important parameters to know in tube matching? The 8 Tung-Sol KT-120's came with numbers on the box from the factory as well as an additional sticker with more numbers on it.  One was Gm and another was IP. Probably other info too. I'm trying to determine what's important when matching up tubes on the M-125.
    Thanks!
    Frank111
    I would say that current measured at a voltage similar to what your amp uses is most important.
    Gm also matters, but as it manifests as amplification it will to a certain extent be
    compensated for by feedback within the amp.
    Dissimilar current will magnetize the OT and affect low frequency's bad.
    Post by sKiZo Thu Apr 30, 2015 11:43 pm
    Plate Current (PC) and Amplification (TC) are the biggies ... shorts and leakage tests as well.
    A well tested tube should also be graded for microphonics and low noise.
    jjones3318
    jjones3318
    Post by jjones3318 Fri May 01, 2015 11:13 pm
    Do you mean Ip and Gm?
    Jim McShane
    Post by Jim McShane Sun May 03, 2015 12:31 pm
    sKiZo wrote:Plate Current (PC) and Amplification (TC) are the biggies ... shorts and leakage tests as well.
    I agree with much of what you wrote, but...
    In many - if not most - amps the bias current is measured by means of a resistor in the tube cathode. Ohm's Law is applied to the voltage measured across the resistor and the current is then known. In a number of other cases an ammeter is inserted in the tube cathode circuit to directly measure the current.
    BUT... the current passing through the cathode resistor (or ammeter as mentioned above) in an amp is not just the plate current, it is the plate current PLUS the screen current (unless the power tube is a triode). Therefore, since the bias (a.k.a. cathode) current is not just the plate current then I believe it is better to match for cathode current than just for plate current - and that's what I do! I also check power tubes and cull out any tubes that have excessively high screen current.
    And BTW, transconductance (abbreviated Gm) is not the same as mu or amplification factor - but I do agree that matching Gm is a real plus.
    Post by Roy Mottram Thu May 07, 2015 2:38 pm
    just my own opinion of course, and in general tube matching is a good thing. I've even paid Jim extra to do it, especially on phono tubes.
    BUT, matching means the tube is matched at that exact voltage and current. Doesn't mean it's matched in the circuit you're using the tubes in,
    that probably has different voltage and current then the "test" conditions.
    Especially for an amp, the amp itself is the best test fixture! Buy a few extra tubes and "match" your own tubes!
    Without changing the bias pot, plug in each tube and read the cathode current. That gives you the numbers.
    Then pick the tubes that "match" closest to the current you want in that amp!
      Current date/time is Fri Apr 19, 2024 11:36 am
