    PAS volume and balance pot replacement question
    Dingojazz
    PAS volume and balance pot replacement question Empty PAS volume and balance pot replacement question
    Post by Dingojazz Wed Jun 10, 2015 7:54 pm
    Hello All,
    Having completed the VTA PAS "ultimate" upgrades, I'm planning to replace PAS 2 volume and balance pots with ALPs pots, and am wondering about the "stereo-mono" pot connections to volume and balance.
    If the ALPs pots go in for balance and volume, can the "stereo-mono" switch connections be bypassed/omitted completely with impunity?
    K
    Dingojazz
    PAS volume and balance pot replacement question Empty Okay
    Post by Dingojazz Fri Jun 12, 2015 8:55 pm
    i gather from archives that this is a bit of a can 'o worms, so to simplify, I'm just trying to see if those stereo pot connects need to be maintained.
    If it's still too sticky I get it.
    K
    PAS volume and balance pot replacement question Empty Re: PAS volume and balance pot replacement question
    Post by Guest Mon Jun 15, 2015 12:30 pm
    99.9% of people upgrading to the ALPS volume and balance control do not bother with the mono/stereo switch, so that can be totally bypassed.
    Dingojazz
    PAS volume and balance pot replacement question Empty Thanks
    Post by Dingojazz Tue Jun 16, 2015 2:28 pm
    Thank you kindly for the response.
    Cheers,
    K.
    Post by GP49 Wed Jun 17, 2015 12:08 am
    You may wish to keep a simple stereo-mono switch. A stereo-mono switch can be useful for those who play mono records or listen to weak FM signals (if the signal is weak, mono FM is less hissy than stereo). A simple SPST switch is all that is needed and in stereo mode it is totally out of circuit, as nothing passes through it.
      Current date/time is Thu Mar 28, 2024 7:10 am
