    ST70 upgrade to VTA70 tube information needed
    McGar
    ST70 upgrade to VTA70 tube information needed Empty ST70 upgrade to VTA70 tube information needed
    Post by McGar Tue Jun 09, 2015 11:04 am
    First time poster here.
    I am upgrading my original ST70 to the VTA board I just ordered from tubes4hifi, along with the triode/pentode switches.  It calls for the 12au7 tubes.  I have been reading lots of great info on this forum for the past couple of weeks and have learned A LOT!
    My question:  I am seeing a lot of organ tubes for sale (baldwin, conn) and military spec tubes for sale on that auction site.  Can anyone give me any advice regarding these (what to avoid or what to look for)?  Also, do I want a matched triplet, or just a matched pair and one odd tube?
    Thanks.  I am sure I will have some more questions later.
    ST70 upgrade to VTA70 tube information needed Empty Re: ST70 upgrade to VTA70 tube information needed
    Post by Bob Latino Tue Jun 09, 2015 12:16 pm
    In the VTA ST-70 CCS driver circuit you can use any 12AU7, 12BH7, 5963, 5814, 6189 or the Mullard CV4003. The last 4 tubes mentioned are military/industrial versions of a 12AU7. All those Conn, Baldwin etc. are 12AU7 tubes that are "rebadged" and made by RCA, GE or Sylvania. They are ALL excellent tubes and much better than any modern Chinese made 12AU7.
    Most tubes made by RCA, GE or Sylvania have the two triode sections on each tube fairly well matched. In general, you don't really need all three of those driver tubes "matched". If you want to buy one tube that has matched sections, use it in the center voltage amplifier position on the ST-70.
    kaner
    kaner
    Post by kaner Tue Jun 09, 2015 10:22 pm
    I have had excellent luck with the rebadged tubes. I run green label "Baldwin" 12ax7's in my guitar amps that are Sylvania's. They replaced some JJ's that were ok, but just couldn't keep up.
    McGar
    Post by McGar Wed Jun 10, 2015 9:33 am
    Thanks for the help, guys. Now I just need to heat up a soldering iron and get this upgrade done!
    Post by Roy Mottram Wed Jun 10, 2015 11:56 am
    all of the Conn and Baldwin tubes I have purchased have been super good quality tubes
    eickmewg
    Post by eickmewg Thu Jun 11, 2015 9:30 am
    I agree, the Conn 12AU7 tubes have worked well for me in my VTA ST120.
      Current date/time is Fri Apr 19, 2024 11:19 am
