    PAS 2 / PAS 3 Identity
    scott6058
    Post by scott6058 on Fri Jun 12, 2015 11:17 am
    May sound silly or could be obvious but how do you tell the difference between the later silver faced PAS units.
    I have one F/S on Epay and may have listed it wrong Sad
    http://www.ebay.com/itm/141687481055?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
    Also what is a Scott LM-35 multiplexer and why do some people want them?
    Thanks for any help.
    Kind regards
    Scott
    Last edited by scott6058 on Fri Jun 12, 2015 11:18 am; edited 1 time in total (Reason for editing : typo)
    Re: PAS 2 / PAS 3 Identity
    Post by peterh on Fri Jun 12, 2015 11:38 am
    scott6058 wrote:May sound silly or could be obvious but how do you tell the difference between the later silver faced PAS units.
    Kind regards
    Scott
    This is a PAS-3
    It might be a PAS-3X but it is not visible from the photos.
    price is right
    scott6058
    Post by scott6058 on Fri Jun 12, 2015 11:52 am
    Thanks Peter
    Any clue on how to identify a 3X.
    On the back it says only PAS.
    Again thanks for the help.
    Scott
    Post by Bob Latino on Fri Jun 12, 2015 1:34 pm
    The PAS-3X has a flat spot near the center of the bass and treble knob's rotation. If you turn both the bass and treble knobs slowly all the way from one end to the other, you can usually feel that "null" position. If the bass and treble knobs have the same feel all the way through their rotation then you have a PAS-3.
    Post by stewdan on Fri Jun 12, 2015 3:18 pm
    Scott -- the LM-35 is a FM Multiplex unit that is used to convert a Mono FM Tuner to FM Stereo unit. Originally intended for Scott Mono Tuners, but can used on other Mono Tuners (brands).
    Stew
    Post by GP49 on Fri Jun 12, 2015 6:21 pm
    Bob Latino wrote:The PAS-3X has a flat spot near the center of the bass and treble knob's rotation. If you turn both the bass and treble knobs slowly all the way from one end to the other, you can usually feel that "null" position. If the bass and treble knobs have the same feel all the way through their rotation then you have a PAS-3.
    Another way to tell: The PAS-3's tone control knobs will rotate through the same size arc as the balance control.
    The PAS-3x tone control knobs have a visibly lesser arc of rotation.
    Post by j beede on Fri Jun 12, 2015 11:46 pm
    Another indicator: If you hear a thump or pop through your speakers when you rotate the bass or treble controls off the 12 o'clock position--you have a PAS-3X
    audioregenesis
    Post by audioregenesis on Thu Jun 18, 2015 1:37 pm
    The PAS 3X tone controls do NOT have a mechanical detent at center. There are a few external clues, however, along with obvious internal differences. Here's an article that describes how to tell if it's a PAS 3 or 3X:
    http://audioregenesis.com/documents/Dynaco%20PAS%203%20or%203X.pdf
    As far as "originally" being a PAS 2 or PAS 3/3X - The PAS 2 is usually typified by the brass faceplate, however Dynaco did supply upgrades kits for both the faceplate, and later, 3X tone controls, so any particular PAS, of unknown background, may have started life as a PAS 2, or 3, and been upgraded at some point.
    Tiziano73
    Post by Tiziano73 on Tue Jun 23, 2015 6:08 am
    audioregenesis wrote:The PAS 3X tone controls do NOT have a mechanical detent at center. There are a few external clues, however, along with obvious internal differences. Here's an article that describes how to tell if it's a PAS 3 or 3X:
    Very nice Article.
    With compliments.
    Tiziano
      Current date/time is Wed Apr 25, 2018 12:39 pm
