    PAT-4 Case | Tubes4HiFi ZMOD Line Board – Blowing 3A Slo-Blow Fuses
    aguaazul
    Post by aguaazul on Sun Jun 14, 2015 9:38 pm
    I had 1 semi working PAT-4, I picked up 3 more, 1 working, 1 not so much and 1 basket case, off of CL for $75. I also met a cool cat who builds tube gear, mostly 6L6 guitar & organ stuff I believe.
    Anyway, prepped 1 chassis, I have a spare Tubes4HiFi v13 power supply, ZMOD line board laying around.
    I grabbed the last I/O board that was available for the PAT-4, found a cool experimenters 7 pin miniature socket board, I have a 21 Step Volume control, ALPS Balance, standard selector switch in hand so I started wiring it up.
    The PAT-4 has room for 4 110v outlets in the back. I am able to use 2 un-switched and 1 switched with the internal configuration.
    I’ve got it put together…. Take a peek here:
    Blue's PAT-4 Case Project
    I decided to keep the 3A Slo-Blow fuse in the AC supply line. In testing with the garage system, it warms up quietly, plays 2/3rds of a song before the fuse blows.
    Should I worry? The Tubes4HiFi v13 power supply has its own fuse.  Do I need a bigger fuse or do I just ditch the fuse all together? Let me know your thoughts.
    Blue
    Dale Stevens
    Re: PAT-4 Case | Tubes4HiFi ZMOD Line Board – Blowing 3A Slo-Blow Fuses
    Post by Dale Stevens on Mon Jun 15, 2015 5:14 pm
    Blue, the 3a fuse in your PAT 4 only protects the pre itself. It is past the sw-unsw outlets so I can't answ why its blowing. Tho I would not up that fuse or displace it.
    Here's what I found; The power switch will not handle lots of on-off loads via the switched outlets. I do one sw outlet that triggers a relay with 120v/20a contacts that cuts on a 8 outlet power strip. The OEM switches are getting rather hard to come by. I'm sure some of our SS folks will come forward w/ more help than I have. Just wanted to point out that load deal. Dale
    aguaazul
    Post by aguaazul on Mon Jun 15, 2015 6:22 pm
    Dale, Thanks for pointing that out. I am rewiring it now. Luckily I have the other PAT's to copy the wiring. I was wiring it up like a PAS-3. Blue
    aguaazul
    Post by aguaazul on Mon Jun 15, 2015 8:02 pm
    That did the trick! Sounds great.
    Dale Stevens
    Post by Dale Stevens on Wed Jun 17, 2015 4:13 pm
    Blue, what did the trick?? I think that's a neat build-up. Oh, and don't do away w/ PAT- parts; there's at least one of us left that can use some of that stuff. PM sent; Dale
    aguaazul
    Post by aguaazul on Wed Jun 17, 2015 5:58 pm
    Thanks Dale, I'm really happy with it, I was wiring the mains like a PAS. It does not work that way with that illuminated switch. After I copied the wiring from one of the other PAT units I have, it worked like a charm.
    I’m having a blast putting this stuff together. I appreciate everyone’s help both public and private.
    I have a VTA TCLA, ZMOD Phono & v14 PS build that went south on me. So, to get something to listen to, I put this together.
    Not only for something to listen to, but prove to myself that I did not screw up the PAS upgrade past the ZMOD to TCLA.
    Best post that issue to its own thread.
    Cheers,
    Blue
      Current date/time is Sat Feb 24, 2018 12:19 am
