    New VTA70 upgrade and a bias problem
    McGar
    New VTA70 upgrade and a bias problem Empty New VTA70 upgrade and a bias problem
    Post by McGar Wed Jun 17, 2015 8:35 pm
    I have finished my VTA 70 install on my old 1960 or 61 ST70.  I have spent a couple of hours researching the board.  I think I have problem solved, but i thought I would ask for some help.
    Bias is way too high.  With pots turned all the way down, bias is leveling off at .70.   I thoroughly cleaned and tightened all the sockets.  And still have the problem.
    Here are some pertinent values:
    red/blk wire bias connection  55vac
    Other end of diode   -45vdc Evil or Very Mad
    each location of pin 6 at board -22.3 to -23
    Across pin 2 and 7 of each output tube  7vac
    rec tube across pin 2 and 8  5.5 vac
    rec tube pin 4 and 6  379vac
    So have I got a bad diode (or did I toast it soldering it in place)?  Or should I look somewhere else?  Can I replace that diode with a 1N4007  or do I need to go the electronics store?
    Thanks in advance for any and all help.
    New VTA70 upgrade and a bias problem Empty Re: New VTA70 upgrade and a bias problem
    Post by Bob Latino Wed Jun 17, 2015 9:17 pm
    You should get about -70 to -75 VDC on the other side of the diode. Try another diode in there.
    Yes - You can use a 1N4007 diode in there ..
    McGar
    Post by McGar Wed Jun 17, 2015 9:58 pm
    AWWWRRRRGGGGGGHHHHH!
    Replaced the diode and still getting about -45vdc. Any suggestions? Diode stripe is through the square hole next to the Bias with the red/blk wire. Any other values I should check?
    McGar
    Post by McGar Thu Jun 18, 2015 7:55 am
    I think I may have it! Sloppy solder connection at C17. Now I am getting 75vdc at the end of the diode.
    Post by Bob Latino Thu Jun 18, 2015 8:27 am
    You should be OK now .. 55 VAC on one side of the diode usually equals about -75 VDC on the other side ..
      Current date/time is Fri Apr 19, 2024 1:52 pm
