    SP14 assembly question
    ramon68
    Post by ramon68 on Wed Jul 22, 2015 12:37 pm
    The various preamp controls - selector switch, left gain, right gain, master volume, have a metal tab on the body which is presumably to keep the body of the control
    from rotating as the shaft is rotated. How does one tighten the control to the panel without deforming the control? Cut a depression into the rear of the panel for the tab,
    or cut off the tab to solve the problem?
    Re: SP14 assembly question
    Post by audiobill on Wed Jul 22, 2015 12:40 pm
    Just bend the tab straight?
    ramon68
    Post by ramon68 on Wed Jul 22, 2015 1:23 pm
    Is that what you did? No problem with the body rotating?
    Frank111
    Post by Frank111 on Wed Jul 22, 2015 1:30 pm
    I carefully cut off that tab from each control, then aligned them and made sure that they were sufficiently tight so that they would not loosen and rotate later. Just don't tighten so much that something cracks!
    ramon68
    Post by ramon68 on Wed Jul 22, 2015 1:38 pm
    OK. Thanks, Guys.
    Post by GP49 on Fri Jul 24, 2015 2:36 am
    A lockwasher between the panel and the control body helps, too.
    pigface
    Post by pigface on Fri Jul 24, 2015 12:01 pm
    Just get out a small file and notch the case . You will not have to  over tighten the nuts or worry about it spinning .
    ramon68
    Post by ramon68 on Fri Jul 24, 2015 12:04 pm
    Good pic, but why on the back panel?
    pigface
    Post by pigface on Fri Jul 24, 2015 5:12 pm
    This is on the back of my PH-15 . I installed a attenuator with different load resistors in it  so I could change the cartridge loading  without takeing it apart and soldering in different resistors .
      Current date/time is Wed Jan 17, 2018 5:06 am
