    Bias KT88 versus 6550 WE
    Skyfrog
    Bias KT88 versus 6550 WE Empty Bias KT88 versus 6550 WE
    Post by Skyfrog Sun Aug 09, 2015 7:37 am
    This question was probably asked before but I cannot find this topic. I obtained some Sovtek 6550WE for my M125. Is there a difference in the bias value? Shall I just replace them and re-bias at 0.60/1.20 like the KT88?
    Thanks bunches.
    Bias KT88 versus 6550 WE Empty Re: Bias KT88 versus 6550 WE
    Post by Bob Latino Sun Aug 09, 2015 8:28 am
    You would just bias a KT88 and a 6550 in your amp the same ... Just as you said > .60 VDC bias voltage per side for two output tube operation and 1.20 volts per side for four output tube operation. The recommended output tubes to use in an M-125 are 6550, KT88 and KT120. You could also use the newer TungSol KT150 BUT > I don't feel that the extra cost for these (they are about $100 a tube) is worth it ..
    Skyfrog
    Post by Skyfrog Sun Aug 09, 2015 9:57 am
    Thanks Bob.
      Current date/time is Fri Mar 29, 2024 12:56 am
