    PAS3 without AC outlets
    jwnash1
    Post by jwnash1 on Wed Aug 12, 2015 12:39 pm
    I am in the process of rebuilding a PAS3 which had been stripped of the AC outlets and the power cord. I could care less about having the convenience of the ac outlets since I would never use them. I am unable to locate replacements and without them I am unsure of the best way to tie in the power cord with the transformer mains, the on/off switch, and the 2 leads which feed from one side the power cord and one of the transformer leads to the power supply. This seems like a lot to wire nut together. Does anyone have any suggestions for a proper way to do this without the AC outlets or know of a source for them?
    aguaazul
    Re: PAS3 without AC outlets
    Post by aguaazul on Sat Aug 15, 2015 3:55 pm
    Kevin at DynakitParts has the black ones. AC-PANEL-OUTLETS-NOS
    jwnash1
    Post by jwnash1 on Sun Aug 16, 2015 4:03 pm
    Thanks, but when you read the listing, they are out of stock.
    GreggW
    Post by GreggW on Tue Aug 18, 2015 3:50 pm
    You could use a 2-lug terminal strip for the AC power cord and to make your connections to the switch and transformer leads. I would not use any wire nuts for any of the connections; they are not a reliable connection. The new regulated power supply from Tube Nirvana is easy to build and works flawlessly. It also simplifies your wiring.
    kaner
    Post by kaner on Tue Aug 18, 2015 11:47 pm
    I wouldn't use wire nuts. I would twist the wires together, add some solder to make sure that you have a solid connection and then cover the whole thing with heat shrink tubing. It makes for a clean and secure connection. BTW, put the tubing on before you make the connection. I've made that mistake before!
      Current date/time is Fri Apr 20, 2018 5:52 pm
