    Another wall voltage question.
    Another wall voltage question. Empty Another wall voltage question.
    Post by Dave_in_Va Wed Aug 12, 2015 2:38 pm
    I have a VTA ST70 (thanks Sal) and a VTA SP/PH 10 (thanks Troy) that sounds great.
    I have about 122/123 volts at the outlet. I also have a bucking transformer that will knock this down to about 115v.
    Does it make any difference which voltage I chose to use?
    Thanks in advance.
    Another wall voltage question. Empty Re: Another wall voltage question.
    Post by Bob Latino Wed Aug 12, 2015 2:47 pm
    Dave_in_Va wrote:I have a VTA ST70 (thanks Sal) and a VTA SP/PH 10 (thanks Troy) that sounds great.
    Thanks in advance.
    Hi Dave,
    Using the amp at 122 - 123 VAC may shorten tube life a bit. It will raise the DC voltages inside the amp somewhat higher than normal. I would try the amp at 115 VAC with your bucking transformer. If it sounds OK, I would use it with the bucking transformer. Tube life will be extended and the amp will not produce as much heat. You may lose 2 or 3 watts of power but you probably won't notice the very slight loss of power.
    Another idea is to substitute a 5U4 for whatever rectifier you are now using (without using the bucking transformer). The use of a 5U4 will drop the DC voltages in the amp and extend tube life a little. This rectifier substitution also comes with a very slight loss of power. ..
    Post by Dave_in_Va Wed Aug 12, 2015 4:37 pm
    Hi Bob,
    Thanks for the info. I just hooked up the bucking transformer*. The bias dropped on each tube about 4-5 mV. Re-biased and everything still sounds gorgeous.
    Man, I love this gear.
    * I paid the big bucks for a NOS Mullard 5AR4 so I'm gonna use it no matter what ;-)
      Current date/time is Thu Mar 28, 2024 7:47 am
