Haven't posted in awhile, hope everyone is doing well. I was privileged to own a pair of Mark IV amplifiers for a year or two and I became a tube addict!! Is there a tube-o-holics anonymous out there? If there was I would need to go! Well I sold the custom pair of Mark IV's that I had built, and decided to graduate up to something a little more grand, possibly the Mark III's, but I was thinking since the Mark IV's are basically the ST-70 on steroids!! I would need to build a pair of Mark III's on Steroids, so my idea is this, fully regulated front end B+, DC heaters to the front end, and a beefier power supply. Have the power supply PCB ready to go, and main board, just need a chassis now to house it in. Any thoughts?
Mark III on steroids!!
j beede- Posts : 473
Re: Mark III on steroids!!
I am a fan of the MkIII. I don't think the power supply has any serious weakness other than the quad cap's marginal working voltage. I replaced the quad cap with an array of series pairs of modern (compact) 450WVDC caps with balancing resistors. This enables solid state rectification and higher B+ when running KT-88 etc.
GP49- Posts : 792
Good comment about modern capacitors. The era of the plasma big-screen TV has come and gone, but with it came renewed production of large electrolytic capacitors of 350-450 volt ratings, easily adapted, as J Beede described, to tube amplifier power supplies...if you have the space available.
sKiZo- Posts : 1530
Can I take that as a "get em while they're hot" kinda thang? Wonder just how long they'll still be available as a major application slides into history ...
denny9167- Posts : 151
sKiZo wrote:The era of the plasma big-screen TV has come and gone, but with it came renewed production of large electrolytic capacitors of 350-450 volt ratings
Hopefully as the interest in tube audio continues to grow, the demand for high-voltage electrolytics will also continue!
» Poor man's solid state replacement rectifier for Dynaco ST-70, Mark II, Mark III or Mark IV
» Run your Dynaco ST-70, Mark II, Mark III or Mark IV in TRIODE MODE - photo
» ST-70, Mark II, Mark III and Mark IV - to check your date of manufacture
» Dynakit Mark 3 cage and Dynaco Mark 2 chassis and bottom cover wanted
» On Board Bias Monitoring for Mark III and Mark IV
