    ST 120 vs MKIII Sound
    eric
    Post by eric on Thu Feb 11, 2010 12:53 pm
    I really like the looks of the MKIII 60 watts but does the sound compare to the st 120?
    Re: ST 120 vs MKIII Sound
    Post by Bob Latino on Thu Feb 11, 2010 3:06 pm
    eric wrote:I really like the looks of the MKIII 60 watts but does the sound compare to the st 120?
    Hi Eric,
    The purpose of the creation of the tube VTA ST-120 was to give the equivalent of two 60 WPC Dynaco Mark III's with VTA driver board on one chassis. By having two channels on one chassis the amp is more cost efficient than having two separate Mark III monoblocks.
    If you are comparing the tube Dynaco VTA ST-120 to two STOCK Dynaco Mark III's, IMHO the driver circuit, power supply and switchable triode/pentode mode of operation give the VTA boarded ST-120 some advantages.
    A. Driver circuit - The original Mark III used a pentode/triode driver circuit with one 6AN8 tube and one bias control for each PAIR of tubes. The VTA ST-120 uses an all triode driver circuit which is an adaptation of the VTA driver circuit as found on the VTA ST-70. The VTA boarded ST-120 has one bias control for each individual output tube. The VTA ST-120 also has an AC balance control to allow you to more precisely set the phase splitter/phase inverter section of the driver circuit.
    B. Power Supply - The power supply on each original Dynaco Mark III has 90 uF of B+ high voltage storage or a total of 180 uF on a PAIR of Dynaco Mark III monoblocks. The VTA ST-120 with capacitor upgrade options has 670 uF of B+ high voltage storage coupled with bypass capacitors to break up resonances in the power supply for better high frequency response.
    C. The stock Dynaco Mark III's may only operated in pentode mode unless you want to open the amp and rewire it into the triode mode. The VTA ST-120 maybe be operated in either triode or pentode at the flick of a switch. Which mode sounds best to you depends on your musical taste and your associated equipment. With the VTA ST-120 you have a choice.
    Any Mark III may be retrofitted with VTA upgrade driver boards and if you also beef up the power supply on each amp you would have a close equivalent of the VTA ST-120. To do so, however, is not as cost efficient as the VTA ST-120.
    As to your inquiry about "does the sound compare to the st 120?". The ST-120, IMHO, sounds better than two STOCK Mark III's and pretty much the same as two VTA boarded Mark III's with beefed up power supplys.
    eric
    Post by eric on Thu Feb 11, 2010 5:59 pm
    Thank you Bob.
    I see the MK III kits advertised around $500.00 each. Do you have a close figure what it would cost to up grade them to be compareable to the ST-120? Would that include the switch to change what mode you wanted to listen to?
    Post by Bob Latino on Thu Feb 11, 2010 6:16 pm
    eric wrote:Thank you Bob.
    Hi Eric,
    The ST-120 kit with the triode/pentode swiches and SCM power supply module included is $795 + shipping.
    The two Mark III kits are $500 each or $1000
    The two VTA driver boards with parts set are $125
    A triode/pentode kit for both Mark III's would be $30
    TWO SCM (supplementary cap module) modules @ $20 each = $40
    Total = $1195 + shipping for two Mark III kits set up with VTA driver boards and two SCM modules
    The ST-120 = $795 + shipping WITH SCM power supply upgrades
    Difference = Two Mark III's will cost $400 more if they are to be set up just like an ST-120
    eric
    Post by eric on Thu Feb 11, 2010 6:53 pm
    [quote="Bob Latino]The two Mark III kits are $500 each or $1000
    Bob[/size][/b][/quote]
    Ouch!!!!!!!!! Thank's Bob. I guess i have to decide if looks are worth $400 more. Would a pair of the MK III run any cooler than the st-120? I listen to my Lascala's pretty loud most of the time if it makes any differance.
    Post by Bob Latino on Thu Feb 11, 2010 7:01 pm
    "Would a pair of the MK III run any cooler than the st-120? I listen to my Lascala's pretty loud most of the time if it makes any differance."
    Hi Eric,
    Yes - The two Mark III's, since they would be separated by some distance and have fewer tubes running on one chassis, would probably run a little cooler. That said, no one has ever reported to me any heat issues or overheating issues with the ST-120. Lascala's are very efficient and probably wouldn't tax either a pair of Mark III's or an ST-120 very much.
    thevic24
    Post by thevic24 on Thu Feb 11, 2010 7:10 pm
    I dont have much experience with the MKIII's but my new ST-120 with a fresh painted and clear coated cage looks dead sexy.
    If I could only find my d*@ camera, I would show you.
    Outstanding amp!!
    -Vic
    eric
    Post by eric on Thu Feb 11, 2010 8:29 pm
    The ST-120 amps are beautiful but something about a pair of MK III amps just appeals to me a little bit more with the exception of the price.Lol
    Luddite
    Post by Luddite on Fri Feb 12, 2010 10:35 am
    eric wrote:The ST-120 amps are beautiful but something about a pair of MK III amps just appeals to me a little bit more with the exception of the price.Lol
    FYI: You don't necessarily have to purchase the complete MK-III kits. Dynakit Parts sells everything individually. You might check the cost to order the chassis, transformers, etc. from them and then order the VTA driver boards, etc. from Roy.
    Charlie
    eric
    Post by eric on Fri Feb 12, 2010 7:11 pm
    bnc31 wrote:FYI: You don't necessarily have to purchase the complete MK-III kits. Dynakit Parts sells everything individually. You might check the cost to order the chassis, transformers, etc. from them and then order the VTA driver boards, etc. from Roy.Charlie
    I may do that. Do they have individual parts that are up grades compared to what comes in the kit?
    Jhoman
    Post by Jhoman on Sat Feb 13, 2010 1:12 pm
    I love my ST120, no heat issues driving my Cornwalls, love the triode mode for jazz and female vocals. Using Mullard 4024s on the pre, Ruby KT88s on the power side.
    Outstanding combo on my system!
    Luddite
    Post by Luddite on Mon Feb 15, 2010 10:51 am
    [/quote]I may do that. Do they have individual parts that are up grades compared to what comes in the kit?[/quote]
    The only upgrades they offer are a choice between carbon composition and metal film resistors on their driver boards (same circuit as the Dyna originals). However, if you buy the basics (ie. chassis, transformers, quad cap, etc.) from Dynakit Parts, then you can use the VTA driver boards and any other upgrades you might choose. You can check out everything Dynakit has to offer at www.dynakitparts.com
    Listens2tubes
    Post by Listens2tubes on Wed Feb 17, 2010 6:49 pm
    I am a monoblock guy. That said, I have been gathering a pair of MkIV's for a more aggressive mod build than my current pair. Finding not so pretty original amps with good tranformers can be a real cost saving method. Just my 2 cents.
    Neal
    Post by Bob Latino on Sat Mar 20, 2010 10:01 am
    Charlie
    Re: What Charlie has mentioned above ..
    You can't really do what you are suggesting and make it cost efficient.
    Two Mark III transformer sets = $424
    Two Mark III chassis = $190
    Two quad caps = $106
    Two chokes = $25
    Two VTA driver boards and parts sets = $125
    Input and output jacks and mounting boards for two amps = about $40
    Eight tube sockets = $28
    Assorted small parts like TWO SETS of the following > fuse posts, fuses, switches, terminal strips, stainless steel hardware, power cords, grommets, grounding lugs etc. - maybe $50-$75
    Total probably around $1000 for parts if parts are ordered separately ..
      Current date/time is Wed May 16, 2012 7:35 pm
