There is a company in Fort Smith, Arkansas (A&M Fabrication) that make custom speakers stands out of square steel tubing for ANY speaker you may want to get up off the floor. They then fill the tubing with sand to add weight so your speakers won't topple over. They also have the outer surface black powder coated for durability. The price (IMHO) is fairly reasonable ($125 - $200 a pair depending on the size of the stand).. Shipping would probably be hefty due to the weight of the stands .. Some speakers do sound better if you get them up off the floor. You may lose a little bass but might gain some better imaging .. You would probably be wise to raise them up at varying heights on a box or some other type of temporary speaker support until you found the height that is best for your speaker. Keep in mind also that some speakers are voiced to be used on the floor and are probably not a good candidate for speaker stands .. Link and photo below ..
A&M Fabrication ... Custom speaker stands ...
Disclaimer - I have no financial interest in the company. The company was mentioned to me by a customer who uses these speaker stands.
