    OT. Does anyone have a Rek O Kut L37?
    Pat R.
    Pat R.
    OT. Does anyone have a Rek O Kut L37? Empty OT. Does anyone have a Rek O Kut L37?
    Post by Pat R. Mon Sep 14, 2015 10:06 pm
    Little off topic but I'm turning to the audio community here in hopes that someone has a Rek O Kut L37. I need a measurement, preferable with a micrometer of the capstan at the 78 section. I am going to make a bushing to slide over the capstan of my L34 so that I can make it an L37. I have a nice collection of 78's and the L37 with a Grado wooden arm (last generation) would be a good table for just that.
    Thanks in advance..
    OT. Does anyone have a Rek O Kut L37? Empty Re: OT. Does anyone have a Rek O Kut L37?
    Post by GP49 Mon Sep 14, 2015 10:30 pm
    I have an L37 though it is somewhat buried.
    But no micrometer.
    Doctor Hugocat
    Doctor Hugocat
    Post by Doctor Hugocat Tue Sep 15, 2015 12:50 am
    You could also try www.vinylengine.com which IMHO is the best forum for vintage record player people. Yes, I like vinyl as well as tubes.
    So tell me again, why am I always broke?
    Pat R.
    Pat R.
    Post by Pat R. Tue Sep 15, 2015 7:03 am
    GP49, if you dig it out someday there is a way to make a measurement without a mic. Do you have an adjustable wrench? if you do and you can put it on the shaft where the 78 RPM wheel hits.. close it around the capstan until it is snug, then remove it. You can then measure the opening with a ruler to get the size of the capstan. I'd really appreciate it if you could do this.
    Pat
    Pat R.
    Pat R.
    Post by Pat R. Tue Sep 15, 2015 7:05 am
    Doctor Hugocat wrote:You could also try www.vinylengine.com which IMHO is the best forum for vintage record player people. Yes, I like vinyl as well as tubes.
    Thanks for the reminder of vinyl engine..
    I like vinyl too (and shellac for that matter).
    Digital source material with it's lack of pops, hiss and scratches is awful nice too.
    Post by GP49 Tue Sep 15, 2015 12:05 pm
    Pat R. wrote:GP49, if you dig it out someday there is a way to make a measurement without a mic. Do you have an adjustable wrench? if you do and you can put it on the shaft where the 78 RPM wheel hits.. close it around the capstan until it is snug, then remove it. You can then measure the opening with a ruler to get the size of the capstan. I'd really appreciate it if you could do this.
    Pat
    I have vernier calipers. That should do.
    Pat R.
    Pat R.
    Post by Pat R. Tue Sep 15, 2015 12:12 pm
    Pat
    Yes most certainly.. I should have written that in my OP.. I was measuring my capstan with an old set myself.
    Thanks.
    Post by GP49 Sun Sep 27, 2015 7:30 pm
    Here is my Rek-O-Kut L37, with vernier calipers measuring the 78rpm step.  I read it as 0.504"
    Hope this works for you!
    Rek-O-Kut L37, measuring 78rpm pulley step with vernier calipers
    Pat R.
    Pat R.
    Post by Pat R. Mon Sep 28, 2015 8:56 am
    Thanks! That should be a big help..
    Pillo69
    Pillo69
    Post by Pillo69 Mon Sep 28, 2015 8:10 pm
    Pat, some ROK models operating at 50 cycles and others to 50 and 60 cycles.
    Is the L37 how it works ?.
    Is there a label on the engine ?.
    Post by GP49 Mon Sep 28, 2015 11:17 pm
    This one is 60hz.  The L-37 and L-34 could be changed between 60 Hz and 50 Hz only by changing the motor, because the drive pulley is permanently bonded to the motor shaft and machined in situ to ensure concentricity.  Unfortunately this makes it impossible to remove the upper motor sleeve bearing from the motor shaft for cleaning.
    Pat R.
    Pat R.
    Post by Pat R. Tue Sep 29, 2015 7:17 am
    Pillo, I wrongly assumed that we were talking about 60hz, since I am in the US. Thanks for pointing out that there were European models made for use with 50hz. My table is a 60Hz us model.
    GP, some years ago I had to convert a Rockola 1434 Jukebox I had just bought back to 78 speed from 45. I had a similar situation in that I had to make the capstan larger. I drilled and fitted a plastic (nylon?) bushing/spacer that I purchased at a local hardware store onto the existing capstan and much like I now hear ROK did, I filed it true and closer to size while on the motor. It worked out rather well. It was only a jukebox so the level of fidelity wasn't up to par with what we demand from our turntables, but all in all it worked out well and played and sounded great.
    Post by GP49 Tue Sep 29, 2015 8:06 pm
    Jukebox or transcription...if the motor shaft/pulley is correctly sized, smooth and concentric, it's all you need. Good luck with your L-37!
      Current date/time is Fri Apr 26, 2024 11:54 am
