    5V3 test vs. 5AR4
    5V3 test vs. 5AR4 Empty 5V3 test vs. 5AR4
    Post by audiobill Fri Oct 02, 2015 8:04 am
    I just wanted to share my test of a 5V3 in an ST70 with KT88s, vs a 5AR4:
    Line voltage: 120
    Voltage across pins 4/6 of rectifier: 716vac
    B+ at pin 8 of 5AR4: 416.0 vdc
    B+ at pin 8 of 5Y3:   411.3 vdc
    In summary, about a 5vdc drop in B+ using the 5V3.
    I'll measure on an ST120 soon.
    Bill
    5V3 test vs. 5AR4 Empty Re: 5V3 test vs. 5AR4
    Post by GP49 Fri Oct 02, 2015 9:35 pm
    That's the quiescent B+ but how about under current draw? We don't hear amplifiers when they are quiescent (zero outout).
    Post by audiobill Sat Oct 03, 2015 6:40 am
    A good thought - but that's not how I tested this.
    Post by GP49 Sat Oct 03, 2015 3:23 pm
    I know, but that is how an amplifier operates when playing music. Current is drawn and different rectifiers, with different internal impedances, will sag different amounts of voltage. The output voltage to the smoothing capacitors thus varies according to current draw, which varies according to the music played. So different rectifiers will sound different, and a no-load test will not give a clue as to the behavior of a particular tube.
    Post by audiobill Sat Oct 03, 2015 3:26 pm
    Again, good thoughts. Please feel free to share your further tests with the group.
      Current date/time is Fri Apr 19, 2024 3:17 am
