    Quad cap temperature
    GreggW
    Post by GreggW on Wed Oct 21, 2015 10:01 pm
    Checked the quad cap temp after running the amp at low volume for an hour. I measured 120 an inch from the top and bottom of the cap and over 200 in the middle. (Room temperature is 75.) Just wondering if this is normal....
    Re: Quad cap temperature
    Post by sKiZo on Wed Oct 21, 2015 11:31 pm
    What amp?
    The quad cap itself shouldn't generate much heat. It's proximity to the iron and tubes that does it. From there, it's all about ambient temperature and air circulation as to how hot it will actually get.
    Bob posted up a pick somewhere around here with test temps of all the components.
    Aha!
    http://dynacotubeaudio.forumotion.com/t828-tube-amps-get-pretty-warm-especially-in-the-summer-photo?highlight=temp
    Notice the difference between the front and rear tubes ... that's due to the rears being sandwiched between the front tube and iron. Not a lot of breathing space. And there's the quad cap, right next to it.
    GreggW
    Post by GreggW on Thu Oct 22, 2015 1:05 am
    I recall seeing this. The back KT88s run 330 or so, but tonight on a whim, I checked the quad cap a few times with similar results. The 5V3a is the rectifier of choice for now, and I wondered if it had an effect on the quad cap. The ST 120 is 3 ½ years old and has very little time on it. The amp's getting better the more it's used...
    Post by Bob Latino on Thu Oct 22, 2015 8:50 am
    GreggW wrote:Checked the quad cap temp after running the amp at low volume for an hour. I measured 120 an inch from the top and bottom of the cap and over 200 in the middle. (Room temperature is 75.) Just wondering if this is normal....
    Tube amps do run pretty warm .. The quad cap will give off a lot of heat when the amp is running. Your ambient temperature was also 6 degrees higher (75 F vs 69 F) than when I ran the heat test. It will be more difficult for the amp to give up heat when the ambient temperature is higher. As such, the amp will tend to run warmer. Photo below from the link that sKiZo posted ..
    GreggW
    Post by GreggW on Thu Oct 22, 2015 11:31 am
    Didn't realize how warm the quad cap gets, but sitting right next to a 300+ degree tube makes sense. I was concerned because the amp was at a very low volume....
    Post by sKiZo on Thu Oct 22, 2015 6:59 pm
    As I mentioned earlier, the quad cap doesn't so much generate heat, as absorbs it ...
    Mine stays nice and cool mounted underneath.
    GreggW
    Post by GreggW on Thu Oct 22, 2015 9:13 pm
    You've got a great looking 120 with a little extra room. Have you ever checked the real power out with those KT120 glass pillars?
    Tubes4ever
    Post by Tubes4ever on Thu Oct 22, 2015 9:16 pm
    GreggW wrote:I recall seeing this. The back KT88s run 330 or so, but tonight on a whim, I checked the quad cap a few times with similar results. The 5V3a is the rectifier of choice for now, and I wondered if it had an effect on the quad cap. The ST 120 is 3 ½ years old and has very little time on it. The amp's getting better the more it's used...
    No. The 5V3a is too far away to effect the quad cap to any great degree.
      Current date/time is Thu Jun 21, 2018 2:40 am
