witch is better wz68 or ws1 in my
pre assembled st 120...i do have the the time delay installed
rfbro wrote:witch is better wz68 or ws1 in my
Bob Latino wrote:rfbro wrote:witch is better wz68 or ws1 in my
With the TDR installed you could actually use either the Weber WS1 or the WZ68 in your amp. I do not think you would hear any difference in the sound of your amp with either installed. The WS1 would probably give a higher B+ voltage which would require a slight bias adjustment.
