I purchased the v19 solid state power supply along with a PH10 phon bd and a TCLA tone control kit the PH10 and TCLA came as kits the V19 power supply was assembled--the v19 was ordered first to replace a cooked transformer -the power caps seemed fine -and there was some newer bds -original style dynaco bds--there were issues so I ordered the nirvana bds-all kits are assembled and in place wiring as directed-I do not get any heater/filaments voltages from the power supply I get 0 -I get B+ 270 and 274v dc at the proper places--121v ac line voltage--15vac across the low voltage transformer legs which is for the filaments--through some diodes that work as a voltage doubler giving me 36vdc-some caps and a 1ohm resistor which seem to ck out then we have a tip2955 pnp transistor-t he emitter has 36v the base 36v --the collector 0v--the voltage regulator has 36v at I 0 volts at o and grnd--I am not all that familiar with transistors but it seems that is the problem--I would like to post a schematic but am not sure tubenirvana would appreciate that-I was hoping someone would be familiar enough with this power supply to give me a few pointers-tubenirvana has not responded as of yet --this is not a complaint they must be busy and help is available on this forum--if anyone knows that it is ok to post the schematic let me know or again a little push in the rt direction -at present the wiring to the heaters is disconnected -one to isolate the problem and two enabling me to turn the board slightly on its side to ck the voltages--thanks --Howie
tubenirvana v19 solid state power supply
Guest- Guest
Hi Howie,
sorry to hear about your issues, and I cannot seem to find any e-mail's you may have sent to me.
Send me an e-mail at sales@tubenirvana.net and we'll go from there!
