+24
jjones3318
richtp
pedrocols
frank
rilayton
batman7349
eickmewg
gener8r
deluxmon
Ed Rosenberger
sailor
mazeeff
poconoman
Gregg R.
harpy
28 posters
    High value items in audio today ...
    High value items in audio today ... Empty High value items in audio today ...
    Post by Bob Latino Sat Oct 04, 2014 11:46 am
    I thought that I would start this thread and have those that are interested post up what they feel are some high value audio related items. These are items that don't cost a lot in relation to their functionality. Maybe list the link to the item also. I will start with a few ..
    1. The Stahl SSVT variable temperature soldering station from Parts Express This costs less than $20 and works well. Use moderate heat for soldering on circuit boards. Crank up the heat level for chassis connections.
    2. Tubes ..
       A. Rectifier tubes. One of the best buys is the Sovtek 5AR4 sold by The Guitar Center. $13.39 each and you get free shipping if your order is over $49.
    Link > Sovtek 5AR4/GZ34 at The Guitar Center
    NOTE - The Guitar Center has recently gone way up on their pricing of the Sovtek 5AR4's. They are now $30+ and not a real good buy anymore.
       B. Shuguang made EL34's. These work really well, sound great and their failure rate is low. There is a fellow on Ebay that sells them for $38.50 for a matched quad with free shipping. Link below ..
    Link > Shuguang EL34's on Ebay
       C. Any of the interconnects or speaker cables sold by either > Signal Cable OR Blue Jeans Cable
    High value items in audio today ... Empty Re: High value items in audio today ...
    Post by Guest Sat Oct 04, 2014 12:02 pm
    Post by j beede Sat Oct 04, 2014 1:41 pm
    Apple AirPort Express $99 or Apple TV $99 either device turns your iTunes device into a wireless music streaming system. Perhaps not quite up to vinyl sonic standards--but this device encouraged everyone in my home to use "high end" audio systems that they had avoided in the past. If you are careful with iTunes' volume control (or if you have a a passive attenuator) you can run the line out from these devices straight into your power amp.
    Ditto on the Sovtek 5AR4 rectifiers from Guitar Center. I have had great results with these in my MkIII and ST-70. I have not purchased any other 5AR4 since I started buying these ~2011.
    Pittsburgh 47257 Digital caliper $9.99 (on sale) from Harbor Freight. I use this to measure guitar strings, inside diameter of panel holes, chassis thickness, tube socket outside diameter (not very standardized!), etc. Switch between imperial and metric with the touch of a button. Probably not recommended by the Mitutoyo, Starret, Snap-on crowd :-)
    Post by sKiZo Sat Oct 04, 2014 1:48 pm
    Mogami's entry level 3000 series RCA interconnects. Well built, quiet, and performing well above their price point. What with 46 interconnects in my system, those qualities are important, and I've never had a bad one.
    http://www.performanceaudio.com/item/mogami-3503/10726/
    I've always gone with high heat on circuit boards. Low heat keeps the iron on the board longer increasing the chances of lifting a pad or trace. I run my Weller station at 715F, keep the tip tinned and fluxed, and use short touches. Touch the iron, then the solder, to the component first to preheat that, and run the tip down to the pad as that heats a lot quicker. Instant puddle that way. I'll come back later and dress all the connections after trimming the leads.
    Works for me, anyway.
    Post by deepee99 Sat Oct 04, 2014 2:15 pm
    I took Bob's advice and use Blue Jeans Cable for most interconnects in my two systems; no disappointments. The outfit that sold me my bi-wired speaks tried to talk me into "upgrading" to some $8k audioquest speaker cables; I could hear no difference.
    If you're into silver (I am) best chap and prices I've dealt with is Paul at Clear Day Cables in Tucson
    http://www.cleardaycables.com/index.php
    Very personable and he'll ship you a trial set of coax or speaker cabling gratis.
    Great thread, Dr. Latino.
    Post by Maintarget Sat Oct 04, 2014 10:33 pm
    Very interesting thread on speaker cables I built mine following the direction on the attached web site at a reasonable cost
    http://diyaudioprojects.com/Power/Low-Inductance-DIY-Speaker-Cables/
    harpy
    harpy
    Post by harpy Sun Oct 05, 2014 1:18 pm
    Post by corndog71 Sun Oct 05, 2014 1:40 pm
    My favorite speaker cables are Kimber 4VS and 4TC.
    Pre-terminated costs more. I recommend if possible to get bare ends to save a few bucks. Check for local dealers or try Www.audioadvisor.com
    I've hand-braided all of my interconnects using Homegrownaudio wire. Makes good internal wire too. Www.homegrownaudio.com
    I highly recommend Isoacoustics speaker stands. www.isoacoustics.com
    ATS Acoustics makes inexpensive room treatment panels that look great and work well. www.atsacoustics.com
    Gregg R.
    Gregg R.
    High value items in audio today ... Empty High value products
    Post by Gregg R. Fri Oct 10, 2014 1:37 am
    Hi Bob, et al,
    1. I used the exact same Stahl soldering station to build my VTA-70 last Feb. Works great! Buy 4 extra tips for only 4.95. I use a Hakko tip cleaner, but P-E has a similar one. Tip Cleaner
    2. Instead of the Sovtek 5AR4, I prefer the Weber WZ-68. Better, tighter, sound and more reliable.
    3. I currently use the Shuguang EL-34s in my VTA-70. Warm, open sound, reliable, with little bias drift! Got them from the site mentioned by Bob. Replaced $159 cryoed EH6550s.
    4. I use Kimber Kable for interconnects. Buy the individual TCSS strands from Michael Percy Audio, and use your power drill to twist them together. Terminate them with Amphenol plugs from Parts-Express. KImber TCSS is also sold by Parts Connexion. PcX
    5. No recommendations for speaker cable. You can re-purpose old speaker cable to use as Power Cords. Much better than the stock IEC wire in the box. Oyaide connectors from eBay. Oyaide
    Thanks for looking!
    Last edited by Gregg R. on Wed Oct 29, 2014 1:05 am; edited 1 time in total (Reason for editing : Added link.)
    poconoman
    poconoman
    Post by poconoman Sun Oct 12, 2014 8:58 pm
    Bob, this should be a sticky! cheers
    mazeeff
    Post by mazeeff Mon Oct 13, 2014 5:32 am
    Ipod Touch 5 or Iphone 5. Under $200 and dropping!
    Based on Ken Rockwell's fine article, I decided to build a complete front end for my ST-70 for less than $200.
    1. Ipod 5 touch or Iphone 5 (under $200)
    2. XBMC on jailbroken Ipod or Iphone. Allows for bit perfect Flac playback from file server. (Free)
    3. Yatse app on Android phone. Allows complete control of XBMC and volume. (Free)
    With the Ipod/Iphone running on clean battery power, I get better sound than any other source that I have tried. People are also a little shocked when they see a tiny Ipod driving the amp! I also get the added benefit of using the XBMC's display for music visualizations while playing.
    http://www.kenrockwell.com/apple/ipod-touch-5g/audio-quality.htm
    Mike
    Post by Roy Mottram Mon Oct 13, 2014 12:48 pm
    to each his own of course, when the Stahl iron first came out around 5-6 years ago I bought one to compare with my Weller STC-100 that cost $50.
    It's $39 now on my website here: http://astore.amazon.com/tub02-20/detail/B000AS28UC
    At that time, that was the single best investment in time and money I'd made in electronics. I used the Stahl for a few weeks, then went back to the Weller.
    Never returned since, so if anyone wants a Stahl that was only used a couple weeks, they can have mine for $15 to cover the shipping cost.
    I also agree with sKiZo, I set my iron at a fairly high temp (not all the way up, but 3/4) and find I can do a perfect solder joint on average in 2 seconds.
    Better to use high heat for 2 seconds than low heat for 5-10 seconds. Solder should melt instantly, and then leave the iron there another second
    to let it completely flow into and around the joint.
    Post by sKiZo Mon Oct 13, 2014 1:06 pm
    poconoman wrote:Bob, this should be a sticky! cheers
    Only if you can make sticky folders and stick your stickies in those, otherwise stick it ... too many stickies as is ... can't see the trees for the forest!
    Some good stuff here though ...
    Gregg R.
    Gregg R.
    High value items in audio today ... Empty Stahl vs. Weller
    Post by Gregg R. Tue Oct 14, 2014 12:46 am
    Either soldering iron will do a good job! Stahl offers 4 extra tips for only about 5 bucks!
    I use a 100 watt Weller soldering gun for bigger jobs, such as chassis work. The Weller is probably 50 yrs. old; just needed a new cord and, of course, new tips. Follow SkiZo's recommendations: high heat to melt solder quickly, then remove iron.
    Thanks for looking.
    sailor
    Post by sailor Tue Oct 14, 2014 4:28 pm
    A few years ago bit the bullet and bought a Weller WES51 now around the $100 range. The best investment I ever made when it comes to electronics. I fully agree with a hot soldering iron, but not to hot. Just like Roy described. I find the hardest thing to get a good soldering joint on is the old fashion soldering strips. I find adding a little rosin flux to the strip and wire before soldering makes it a lot easier. I also have several tips but for overall tube electronics usage the flat head that comes with the unit works the best. I use 60/40 no clean and stay away from silver, no lead and boutique solders. I know of one person who had a solder meltdown in an amp. that was soldered with WBT solder. An easy melt solder designed for interconnects but now sold as a high end solder for everything. But to each his own. Again just my 2 cents.
    poconoman
    poconoman
    High value items in audio today ... Empty AOYUE 9378
    Post by poconoman Wed Oct 15, 2014 10:05 am
    Since we're talking about soldering irons, I'll join the band wagon.
    THIS is one great machine. http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2059210.m570.l1313.TR0.TRC0.H0.XAOYUE+9378+&_nkw=AOYUE+9378+&_sacat=0
    Post by audiobill Wed Nov 05, 2014 1:25 pm
    I just picked this up for an ST-70 build, and it's very useful:
    http://www.ebay.com/itm/Pro-Line-Helping-Hands-Soldering-Station-with-10-LEDs-Illuminated-Magnifier-/171251727604?pt=LH_DefaultDomain_0&hash=item27df65fcf4
    This one is better built than current model from Radio Shack.
    Note that "Best Offer" is accepted, so you may get this for less Smile
    Post by sKiZo Wed Nov 05, 2014 5:11 pm
    Speaking of DACs ... I love my Maverick D1+ ... performs WELL above it's price point.
    High value items in audio today ... D1_plus_top2
    High value items in audio today ... D1_plus_back
    High value items in audio today ... Maverick-d1plus_naked_sm
    http://www.mav-audio.com/base/product/d1p/dac_comp_d1p
    Has a tube pre built in that adds a lot of flavor to the music coming into the ST120. Stock is great, but it really shines with opamp upgrades (OPA627 x2) and an upgrade to a decent NOS tube. Maverick does have a GE 5 Star as an option instead of the Chinese tube. I got that and also quite a collection of 5670 alternates for rolling. Primary source for digital music is an HTPC server - supposed to have real decent audio built in, but the Maverick is a HUGE step up from that.
    PS ... they also offer a D2 which is a better digital performer, but you do lose the analog inputs. I plug my turntable into that via an external stage for some of that tooby goodness from vinyl ... also, I prefer the sound of the Tenor chipset on the USB side of the D1+. It just works exceptionally well with my system. Nice to have options though.
    Killer headphone amp also ... real popular with the college crowd and late night listeners.
    Ed Rosenberger
    Post by Ed Rosenberger Thu Nov 06, 2014 3:53 pm
    I purchased a Heathkit GH-17A Soldering Station way back in the early '70's....S/N 07539. I believe I paid around $20.
    The unit still works great and has the original spade tip that still looks new. It has melted many feet of solder, helping to build several computers with discrete components, test equipment, radios, HiFi stereos and many other small projects, including those that my children made. I still enjoy its "feel" while using it and I'm looking forward to building this ST70 with the octal driver board.
    I will most likely wear out before it does....
    http://www.w6ze.org/Heathkit/Heathkit_005_GH17.pdf
    deluxmon
    deluxmon
    High value items in audio today ... Empty Love the Valve Arts EL34's
    Post by deluxmon Thu Nov 06, 2014 6:31 pm
    I agree with one of the High Value item's in Bob's post at the beginning of this thread.
    The Shaguang (Valve Arts) EL-34's are a great bargin and sound great to my ear.
    Ed Rosenberger
    Post by Ed Rosenberger Sat Nov 08, 2014 8:58 pm
    Post by sKiZo Sat Nov 08, 2014 10:39 pm
    I still like this one ...
    High value items in audio today ... 41XDsihA10L
    http://www.amazon.com/TRC-90033-Shockshield-Portable-Protection/dp/B000XVG72G/ref=sr_1_5?ie=UTF8&qid=1415500409&sr=8-5&keywords=gfci+adapter
    TRC 90033 Shockshield White Portable GFCI Plug with Surge Protection
    Placed between the wall power and amp, it requires a manual reset on ANY momentary blip that can otherwise do some serious damage.
    Priceless.
    gener8r
    gener8r
    Post by gener8r Sun Nov 09, 2014 12:50 am
    Check out the drivers (and other assorted items) at this site.   I have built some quite decent sounding speakers very inexpensively from here:
    http://www.mavin.com/
    Post by deepee99 Sun Nov 09, 2014 1:42 pm
    sKiZo wrote:I still like this one ...
    Priceless.
    Yep. Required equipment.
    eickmewg
    Post by eickmewg Mon Nov 10, 2014 7:56 am
    Priceless.
    I just got one of those based on all the positive recommendations.  Thanks sKiZo!
      Current date/time is Thu Mar 28, 2024 9:30 am
