    2.8v on the bias left bias #8
    fmorelli
    Post by fmorelli on Fri Dec 18, 2015 10:06 pm
    Hi all, looking for some debugging pointers. My VT120 has been running for a few years, and I love it. It's pushing a set of very efficient Klipsch CF-4's. The other day I was listening to it in my shop and pop, all went dead. It has Genalex Gold Lion KT88's and a JJ tube rectifier. Turned out the 5A slow blow fuse popped. So given about 3 years of operation and questionable lifespan on the JJ's from what I've read, I figured it was high time to get a Weber WZ68, which I did.
    I know I need to rebias the amp. So I pulled all the tubes but front left, set the switches back, plugged in teh WZ68, and a new 5A slow blow fuse. Set the meter on pin #8, and fired her up. Once the delay ran out, the voltage slowly climbed to 2.8V with the bias turned all the way down (counter clockwise). Strange. So I proceeded to install each additional tube which came in low with their respective bias knobs turned down. I adjusted each to .500V. For grins I turned the amp off, then started it again. Same thing. I swapped tubes at front left and of course same thing.
    So I'm wondering what went south? Thoughts?
    Filippo
    Re: 2.8v on the bias left bias #8
    Post by Bob Latino on Sat Dec 19, 2015 9:55 am
    Hi Filippo,
    Your amp may have a damaged 10 ohm bias resistor on that left front tube socket. With the amp OFF and your meter set to resistance, measure the RESISTANCE to chassis ground at the bias measuring point for the front left output tube and see if you get about 10 ohms. You should probably measure the resistance at the other 3 bias measuring points also just to make sure that you do get about 10 ohms.
    Post by peterh on Sat Dec 19, 2015 2:35 pm
    If the 10 ohm resistor is "blown" the cause is a flash-over in this tube. This killed the gz34 (probably)
    and the 5A fuse.
    Replacing the GZ34 won't be enough, you should consider a new set of power tubes.
    A tube that has flashed will most likley do it again.
    fmorelli
    Post by fmorelli on Sun Dec 20, 2015 2:04 pm
    Thanks Bob and Peter. I've gone ahead and ordered up another set of tubes since I have a fair bit of time on these (and the remaining match set gives me a spare pair). I'll flip this guy and check the bias resistor. I'll report back for posterity sake once finished.
    Thanks again!
    Filippo
    fmorelli
    Post by fmorelli on Thu Dec 24, 2015 3:49 pm
    Hi Guys, ok I have more information, and hopefully enough to debug. Hopefully Bob sees this post. I'll remind this is an ST120. A recap is that 3 power tubes bias fine, and one does not, holding steady at 2.8v at the test point. It was suggested that the 10 ohm bias resistor may have been shot when the KT88 flashed.
    Here's what I have:
    - the 10 ohm resistor checks out fine on the multimeter
    - pin 5 on the octal socket reads 20v, adjusting the bias pot changes nothing
    - checking the other 3 power tube sockets, I can swing 20v to 58v
    soooo .... thoughts? Would it be a bad bias pot?
    Thanks, folks!
    Filippo
    Post by Bob Latino on Thu Dec 24, 2015 3:53 pm
    Filippo,
    Before you try replacing the bias pot > Resolder the 3 solder connections on that bias pot and then see if you can now get a range of -20V to -58V like on the other 3 bias pots. Those are NEGATIVE DC volatges ..
    fmorelli
    Post by fmorelli on Thu Dec 24, 2015 11:31 pm
    Actually I may have figured it out. Looks like a solder joint went bad on the PCB board, for the left front bias pot. The joint had a hollow in the middle of it. I'm now getting the full sweep on pin 5. I'll assemble and test the complete unit tomorrow and report back.
    Filippo
    p.s. Oops posted and then saw Bob recommend I check the pot solder joints. Yep ... and thanks, yes, negative voltages.
    fmorelli
    Post by fmorelli on Fri Dec 25, 2015 1:05 pm
    Alright, all is back together and running, with a new match set of KT88's from Genalex, which gives me a spare set of tubes. The Weber WZ68 is in, and all biased to .500v and holding nice and steady when warmed up. I learned a few things I want to pass along to others - those will little experience, as they will be "duh" for anyone with a clue:
    - My amplifier had become a bit noisy. That was a sign of something starting to happen. Now all together with a few joints reflowed, it is dead, whisper quiet.
    - I did not frequently check the bias. Dumb in hindsight. I would have caught this issue, most likely. I'll check it monthly from here on out.
    This amp has been a joy these past three or so years. Through my Klipsch CF-4's it fills my luthiery shop with joy.
    Thanks, Bob, for the support.
    Filippo
    Post by peterh on Fri Dec 25, 2015 1:25 pm
    As the chain of events seem to be a faulty bias pot(which is fixed now) chances are that your tube
    did not be faulty at all. You should save these set for future use.
    fmorelli
    Post by fmorelli on Fri Dec 25, 2015 11:31 pm
    The bias pot the was not faulty (I have not replaced it), but rather a solder joint was faulty at the bias pot. I'm pretty sure that tube got cooked. Of the four tubes, it's the only one whose silk screen is now beige (the rest are red). Before fixing the solder joint, I couldn't get less than 2.8v at the bias point. I think the safe bet is to send that tube to the dumpster in the sky. I'll keep the rest as spares.
    Filippo
    Post by Bob Latino on Sat Dec 26, 2015 8:56 am
    fmorelli wrote:The bias pot the was not faulty (I have not replaced it), but rather a solder joint was faulty at the bias pot. I'm pretty sure that tube got cooked. Of the four tubes, it's the only one whose silk screen is now beige (the rest are red). Before fixing the solder joint, I couldn't get less than 2.8v at the bias point. I think the safe bet is to send that tube to the dumpster in the sky. I'll keep the rest as spares.
    Filippo
    Just to mention for others ... Every now and then someone will build and amp and it will run perfectly fine for weeks, months and even (as in the case with Filippo's amp) YEARS. Then for no reason a problem comes up. When I hear that swapping and/or replacing tubes does not help, I think > BAD SOLDER JOINT ... Why now after 3 years ? Sometimes after MANY repeated heat (expansion) and cool (contraction) cycles a solder connection will go partial. This connection will now not be electrically perfect. It LOOKS GOOD but the connection is not totally there. This is more likely to happen on a connection for a bias pot because the three pins on the bias pot do not have much surface area to hold solder.
    Another bad solder connection issue symptom is > "The amp runs fine when it is cold but after 1/2 hour I lose the left (or right) channel". When the amp is cold the solder connection is OK but the heat of the amp causes expansion and the electrical connection is lost. Sometimes on original Dynaco amps with the open solder traces on the bottom of the board, a solder trace can actually break when the amp heats up. The usual result is noise on one channel or the loss of that one channel completely.
    Post by peterh on Sat Dec 26, 2015 11:00 am
    The lead-free solder is to blame for lots of these problems. Its more difficult to solder, it
    heats the components much more ( most important for surface-mount ) , and it degrades
    in a way that 60/40 tin never did.
    Post by Bob Latino on Sat Dec 26, 2015 2:53 pm
    peterh wrote:The lead-free solder is to blame for lots of these problems. Its more difficult to solder, it
    I agree with Peter here .. I only used lead free solder once and did not like way that this type of solder flowed when heated. I never used it again ...
      Current date/time is Thu Apr 19, 2018 10:43 pm
