    Rane AC22 active crossover with st35 and st70 problems.
    scott6058
    Rane AC22 active crossover with st35 and st70 problems. Empty Rane AC22 active crossover with st35 and st70 problems.
    Post by scott6058 on Sat Feb 20, 2010 5:54 pm
    Has anyone bi-amped their system with some pro audio gear such as the Rane AC22. It seems to me an easy thing but I get a horrible buzzing sound when I power it up. Input and outputs are 1/4" and I simply cut up some patch cords and fitted the male 1/4" to the ends. Any help would awesome. No
    xlr8
    Rane AC22 active crossover with st35 and st70 problems. Empty Re: Rane AC22 active crossover with st35 and st70 problems.
    Post by xlr8 on Sun Feb 21, 2010 10:25 am
    I use 2 DBX 234 active crossovers and had a similar issue at first. I found that running a ground wire from one of the screws on the chassis to my system ground solved the buzzing. My system ground consists of 3 stacked 10' ground rods outside the house with a #2 solid tinned copper wire run to a bus bar inside. I also found that an ungrounded cable tv splitter caused some unwanted noise as well.
      Current date/time is Thu May 23, 2019 7:59 am
