    PAS2 turntable grounding?
    Drugolf
    Post by Drugolf on Fri Dec 25, 2015 11:30 pm
    How do I ground my turntable with my Pas2 pre since it doesn't have any place identified for it? I tried one of the screws on the I/O board but still got a lot of hum. Hmmm...
    Merry Christmas!
    Re: PAS2 turntable grounding?
    Post by peterh on Sat Dec 26, 2015 3:30 am
    Ground the chassies in all your things ( at least tie them together, don't forget the record player) and then have at least one of them connected to ground in the outlet.
    The phono cable is sensitive ( more or less depending on brand of cable) for both electric and
    magnetic fields, route it as far from other power cables as possible. Don't collect excess cable in
    a roll.
    Post by GP49 on Sat Dec 26, 2015 12:47 pm
    Minor clarification. If any of your gear has a three prong plug, and it is plugged into the AC outlet ground, a separate ground wire to the third outlet pin or the screw in the outlet plate will cause a ground loop. This is more critical in a phono system than in one with only line level sources but is worth remembering.
    Drugolf
    Post by Drugolf on Sat Dec 26, 2015 9:51 pm
    This is a mostly vintage system. Pas2 pre, Dynaco ST70 amp wharfedale speakers. none of which have the ground prong of course. They are plugged into an APC surge protection bar. I also have a DAC connected to the aux input that is connected to a computer via USB. Turntable is Technics with the original power cord and RCA cord/jacks. None have the 3rd prong. The only thing that does is the APC power cord. The hum is only when the Pre is set to Phono.
    Post by j beede on Sat Dec 26, 2015 10:23 pm
    Do you hear hum with phono selected but with the actual phono inputs shorted? Do you happen to be using a Grado pickup?
    anbitet66
    Post by anbitet66 on Sun Dec 27, 2015 12:31 am
    Drugolf,
    If your Technics turntable has a separate ground wire, attach it to one of the chassis screws on your pas2. If that write is not attached there will be a lot of humming. It is attached to the tone arm separate from the RCA plug ground. Tony
    Drugolf
    Post by Drugolf on Sun Dec 27, 2015 2:11 pm
    Yes, the TT has the separate grounding wire. I did attach it to one of the screws on the side (that secures the cover). Also one of the small screws on the I/O board. no improvement.
    How do I short the RCA cables? Touch them together?
      Current date/time is Thu Jun 21, 2018 12:07 am
