    Multi cap help please Knight KA 40
    rfbro
    Post by rfbro on Wed Dec 30, 2015 12:23 am
    does anyone know where to find the following multi caps or suitable subs
    30/30 uf 400/450 volts electrolytic
    30/30/30/50 uf 300/200/150/25 volts electrolytic
    or can i just buy ea value and bundle them together  Bob B
    Re: Multi cap help please Knight KA 40
    Post by GP49 on Wed Dec 30, 2015 2:07 am
    Unless you are concerned with maintaining stock appearance, purchasing separate capacitors of appropriate rating would be just fine. Current capacitors are much smaller than ones from the era of your Knight, so there would be little problem fitting them onto your chassis.
    Post by j beede on Wed Dec 30, 2015 2:46 am
    I always replace the multi-caps with far cheaper discrete electrolytics. I mount the modern caps under the chassis and leave the old can in place to retain the vintage look.
    rfbro
    Post by rfbro on Wed Dec 30, 2015 11:05 am
    j beede wrote:I always replace the multi-caps with far cheaper discrete electrolytics. I mount the modern caps under the chassis and leave the old can in place to retain the vintage look.
    They must be polarized yes
      Current date/time is Wed May 23, 2018 1:22 am
