    dynaco pas z-mod worries
    darkar3796
    Post by darkar3796 on Wed Jan 06, 2016 11:05 am
    I just gradually powered-on a recently completed z-modded dynaco pas 2 preamp (pc5, 6 and power supply). I am hearing little popping sounds that has me worried components are overheating. Tubes look fine but the transformer seems to be running a bit hot. The preamp operated OK before the mod.
    Thanks for any advice.
    Re: dynaco pas z-mod worries
    Post by tubes4hifi on Wed Jan 06, 2016 2:03 pm
    which power supply did you use? How many tubes are you running between the two boards?
    you should contact your supplier directly about this . . . . support@tubenirvana.net
    darkar3796
    Post by darkar3796 on Wed Jan 06, 2016 2:35 pm
    Thanks for letting me know about Tube Nirvana support-- I'll check-in with them.
      Current date/time is Tue Jan 16, 2018 3:32 am
