All original
It needs some other parts after all those years
Where to start ........
The output transformers of this one the same as in the ST70 ....?
Thanks all
Paul229 wrote:Just got the Dynaco sca 35
All original
Thanks all
if it ain't broken, don't mess with it with one exception :Paul229 wrote:Just got the Dynaco sca 35
All original
Thanks all
Paul229 wrote:At the back there is the wire connections for speakers
the 1ste one is interconnected with a funny wire
Should those two be connected...?
Yes, there should be a wire connecting the 2 leftmost ( viewed from the back) terminals.Paul229 wrote:At the back there is the wire connections for speakers
Paul229 wrote:Okay Thanks
You know why one output transformer is getting warm while the other one stays room temperature does not warm up at all...
This unit was out of business for 30 years so maybe there is something i do not consider
Have to keep a close watch on what is going on
I do not like one is hot /warm the other one just room temperature.....
Paul229 wrote:Replaced the two Aerovox caps in power supply
But ran a problem second Capacitor
C 23 Lug
(1) 320v
2 250v
Pin 1 is connected with a 22K to pin 2 of the aerovx 50/50uF
Giving it 150v
Schematics says 250v
Which one is right ...the 22k resistor in there.....to follow- or the schematics...?
Paul229 wrote:No not needed
Amp is good with upgrades.
