    second choke
    golnie
    second choke
    Post by golnie on Thu Feb 18, 2016 5:56 pm
    I recently put a VTA board in my ST-70 and I love it.  With the VTA board, my ST-70 sounds as good if not better than my Marantz 8B (I hope I didn't start a jihad with that statement) . I would like to put a second choke in the ST-70. Would it be wired in series or parallel to the first choke? BTW the ST-70 has the larger power transformer. Thank you in advance for any help.
    Frank
    Re: second choke
    Post by j beede on Thu Feb 18, 2016 6:53 pm
    It depends... if you want to shorten the life of your rectifier put the second choke in parallel with the first. If you want to lower your B+ and alter cathode bias put the second choke in series.
    What are you trying to accomplish?
    golnie
    second choke
    Post by golnie on Thu Feb 18, 2016 7:40 pm
    Hi, I noticed that the ST-120 uses a second choke. I would like to use a second choke for more filtering. I have SS rectifying with 3 amp diodes.
    Thank you for your reply.
    Frank
    nmchiefsfan
    Re: second choke
    Post by nmchiefsfan on Mon Feb 22, 2016 5:52 pm
    Golnie, I am pretty sure the 2nd choke is wired in parallel with the 1st one.
    Re: second choke
    Post by Guest on Mon Feb 22, 2016 7:07 pm
    nmchiefsfan wrote:Golnie, I am pretty sure the 2nd choke is wired in parallel with the 1st one.
    yes it is indeed!
    Re: second choke
    Post by Bob Latino on Mon Feb 22, 2016 7:12 pm
    The VTA ST-70 only needs one choke. The ST-120 and M-125's use two chokes. The primary reason why the two chokes are in there is to handle more current. A single C24-X choke will handle 240 milliamps which is fine for the ST-70. The ST-120 and the M-125's draw more current so the second C24-X choke is used.
    golnie
    Re: second choke
    Post by golnie on Tue Feb 23, 2016 9:31 am
    Thank you for your replies. I will leave well enough alone and just use one choke.
    Frank
    Re: second choke
      Current date/time is Sat Jun 23, 2018 7:44 pm
